MOTIV Motorsport/PTF Hardware release
08-03-2014, 09:53 AM | #1 |
38
Rep 634
Hey guys, we are thrilled to finally make public the hardware we have been designing and testing of the last ~18 months.
MOTIV Direct drop in LPFP system upgrade. This system will be 100% plug and play. Simply remove your old bucket, drop in the new one(using factory connectors)and run an 8AN line using the routing of the factory hose and you are done. This design will change a little before going into full production. MOTIV PI fuel system. Makes use of Bosch fuel injectors being driven by the customers choice of options(AEM, proEFI etc.) In this configuration the fuel system can support upwards of 1000hp. PTF twin disc clutch setup. We are proud to present a twin disc setup we have been working with SPEC to produce and manufacture. Offering a torque rating of +900ftlbs but better drivability than some of the other higher output rated single clutch designs currently available. MOTIV single turbo Kit. This series of pictures shows the progression of the assembly of the manifold and final assembled product. You may be wondering why we went with a bottom mount short runner style manifold and the answer is this: it works the best. We went through designing and testing 7 manifold designs(some just small variations but others complete redesigns) over the course of over a year before finally selecting this design. The great thing about having a fully prepped and dedicated road course/time attack car is that we are able to simulate extended use and wear in a short amount of time. Using a top mount manifold design just simply never worked. Rather than the heat spooling the turbo and then evacuating it would simply radiate in the engine bay creating limp mode inducing oil temps in 2-3 laps and eventually causing valve cover gasket cracking/leaking and other soft part failure. Add to that the 500-600rpm delay in spool compared to using the same turbos in a bottom mount configuration it made the design choice easy. It is a short runner style manifold but far from just run of the mill stuff. Using relatively large ID runners we are able to maintain flow at higher engine speeds but still have unmatched spool. Using 100% CNC billet material and the best fabrication skills available to finalize and assemble to components means a manifold design that will never crack, leak, warp or otherwise fail. Last edited by Allen@MOTIV; 08-03-2014 at 10:45 AM.. |
08-03-2014, 10:19 AM | #2 |
44
Rep 696
Drives: 2012 E70 X5
i so can't wait for the turbo upgrade
great work everyone
2011 BSM 335i E90 MTECH 6MT JB4 stage 2 iso 5.3 FF wire BMS Intake Vishnu DP Cyba Scoops LUX V4 6000K Headlight/Fog light Philips Ultinon Euro headlight switch ACS roof wing 35% tint Performance Grilles Misc coding Cobb charge pipe ///M3 fenders 335is pedals BC Coilovers Vrsf 7" IC ///M3 mirrors
08-03-2014, 12:22 PM | #3 |
93
Rep 716
Drives: 2015 YMB M3
These are great news. Good job guys, any ETA on when your products will be available for purchase?
2015 BMW M3 | DCT | Yas Marina Blue | Silverstone | Executive | Lightning | Driver Assistant | Carbon Ceramic Brakes Instagram: @benrivasplata |
08-03-2014, 12:53 PM | #6 | |
44
Rep 696
Drives: 2012 E70 X5
yes all 3 turbo options will be available for the n55
08-03-2014, 12:55 PM | #7 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Now I need to go change my underwear, thanks! That turbo system looks awesome!
08-03-2014, 01:26 PM | #10 |
44
Rep 696
Drives: 2012 E70 X5
Now all we need is a Kat Fix for our cars
08-12-2014, 02:47 PM | #11 |
44
Rep 696
Drives: 2012 E70 X5
Any updates?
08-12-2014, 03:15 PM | #13 |
314
Rep 929
Drives: 2011 BMW 335i xDrive manual
can't decide if I'm more excited about the turbo upgrade or more worried that my steptronic can't handle all that power
08-12-2014, 09:01 PM | #15 |
44
Rep 394
Please tell me you're being serious this will be compatible with my N55 thank god at long last. I can't wait for this to be released I'll be the first to get it
08-12-2014, 10:49 PM | #17 | |
38
Rep 634
Yep, N55 compatible |
08-12-2014, 11:15 PM | #18 |
127
Rep 1,054
I WANT ONE OF EVERYTHING THANKS!
And a tune for 2012 DME that is currently uncracked outside of Dinan
08-13-2014, 03:58 AM | #19 |
44
Rep 696
Drives: 2012 E70 X5
08-14-2014, 03:08 PM | #20 |
32
Rep 373
I think this might be the best post I've ever seen.
2011 335i sedan 6MT, 515whp/530wtq. Pure Turbo Stage 2, Motiv SST TwinDisk Clutch/FW, Motiv Flash, AA 4" DP, ER FMIC, AA turbo-back exhaust, Quaife LSD, ST Coilovers, BMS Intake, UUC DSSR+SSK, ER CP, BMS CDV, BMS OCC, Arkym CF trunk
