How to diagnose k-can
08-03-2014, 05:14 AM | #1 |
41
Rep 328
Hi,
My car with auto. transmission was originally deliver with aux. heating and complete bluetooth. I've removed both options from the car inc. the wiring of those options. I also removed the most bus. (from google http://www.bellbottomblasters.com/images/bmw17.jpg) When I now insert the key and press the start button (where all the lights of the cluster should light up) nothing happens however when I press the brake pedal I can start the car and steering works. (didn't drive the car) When the engine is running I get a couple or red icons on the cluster. (abs, parking brake, dtc, engine etc.) The elz isn't working either. I hear no sound. So basically all modules are dead. Also when I tried to diagnose the car there is no signal from +15 when the engine is running +15 has 13,xxV but still can't diagnose. I've measured +15 into cas module and it's receiving 12V on +15. I also can't put the selector in P. I've to do i manually. My question is who has any experience how to solve this? How to diagnose k-can? My hardware is an Icom with ista-p, ista-d, ncsexpert and inpa. Any help and links will be appreciated. |
08-03-2014, 11:15 AM | #2 |
1911
Rep 13,104
Your question and what you did don't have details.
If you have a Most based car you can't take out anything in the loop and expect things to work. You don't say which sound system you have if you have L7 and you take out anything in the Most loop you won't have sound .(cause you broke the Most Ring) The other two common systems would work. Bluetooth varrys from year to year in which modules if any are used to make it work. I don't know if this is a language problem but you need to state things like what the year and model of the car are and the options. Especially type of Sound system and Nav or Pro Radio. If you have diagnostic questions you would be better off taking them to the coding subforum. If you ripped out the Most Bus and I would guess an Icom cable wouldn't work as it uses the Most Bus( icom b is a direct most bus connection). A Can bus cable should still work with Inpa at least at the OBD Port.. I would put things back the way the were and see if the problems go away for starters. The voltages seem fine or close to fine. I would think Inpa would still work over the OBD connection. http://www.e90post.com/forums/forumdisplay.php?f=368 Last edited by ctuna; 08-03-2014 at 11:57 AM.. |
08-03-2014, 04:24 PM | #3 |
41
Rep 328
Hi,
Definitely not a language problem. Car details: europe E90 from 2006 with automatic transmission. It left the fabric with aux. heater and bluetooh. I've removed the aux. heater and bluetooh inc. wiring from the car. Now I'm going to assemble the car again. The most bus is for audio etc. It's separate from the bus where elz etc. is. The car has stock audio. I've already tested it with Inpa and ignition is missing. Putting it back again is really not an option. Too many wires and work. What I would like to know is how alle protocols (k-can etc.) of the car work. Let me know if something is still unclear. Edit: I've just find some info. I'll have a look at it. Last edited by Teq; 08-04-2014 at 03:20 AM.. |
08-03-2014, 05:46 PM | #4 |
1911
Rep 13,104
This statement makes no sense at all . And you still didn't say which audio system you have or why you are taking this stuff out? Also you might try bmwcoders.com Last edited by ctuna; 08-03-2014 at 05:52 PM.. |
08-04-2014, 03:36 AM | #5 | |
41
Rep 328
Stock audio which means no l7, harman kardonn, hifi or individual. Just 2 speakers under the front seat and speakers on the door boards. I'm going to install this in another car. Ok. |
08-04-2014, 11:07 AM | #6 |
1911
Rep 13,104
fabric is a piece of cloth in the US
fabric is a piece of cloth or clothing material in the US.
factory is the place where it is was made. Last edited by ctuna; 08-04-2014 at 03:44 PM.. |
