Loss of all sound...Can i just switch out a different stock Amp?
07-31-2014, 02:58 PM | #1 |
251
Rep 1,869
Hey guys, first off I've done plenty of research, and I'm not a electronics guy by any means. So if you are posting to bitch at me to search, then please don't. I'm looking for straightforward answers.
I have a e90 2009 335i, with Hi-fi sound system. -once before my sound suddenly all disappeared (radio, iPod, pdc, seatbelt gong...complete silence) I just reset my battery and it solved the situation. ....however after a rainstorm, it happened again, and I go to find some moisture in my amp area, I have a feeling I shorted out my amp due to a f*cking leak from my trunk somewhere -I'm not sure where the fuse exactly is, but I checked most in the glove compartment. I would rather buy an amp on ebay and be done with it, can i just buy any logic 7 amp and plug and play? Or is it more complicated than that... http://www.realoem.com/bmw/showparts...65&fg=25&hl=17 Or a aftermarket plug and play amp that I can just replace with my stock amp, like I said, I know nothing about car electronics and I'm looking for some help. Let me know if you need any other information. Thanks Last edited by Lshaw; 08-01-2014 at 03:05 PM.. |
07-31-2014, 03:04 PM | #2 |
28
Rep 609
http://www.bimmerfest.com/forums/sho...=1#post5791690
In your case, skip adding front speakers? Get with Technic to purchase that harness. |
08-01-2014, 02:37 PM | #3 |
251
Rep 1,869
Added pics of the amplifier
seems like a decent amount of corrosion.
07 335xi (2007-2010)
08 Legacy Spec B (08-) 09 335i (2010-) 15 X5 xdrive 35i (2015-) 17 Forester XT (2016-) |
08-01-2014, 02:41 PM | #4 |
456
Rep 2,749
water drain kill any new amp until you fix problem
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
08-01-2014, 02:50 PM | #5 |
251
Rep 1,869
08-02-2014, 06:29 AM | #6 |
456
Rep 2,749
do you have sunroof ?
08-02-2014, 01:07 PM | #7 | |
251
Rep 1,869
08-04-2014, 10:54 AM | #8 |
814
Rep 3,953
Check the tail light and trunk seal.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
08-04-2014, 08:55 PM | #9 | |
251
Rep 1,869
08-05-2014, 09:40 AM | #10 |
456
Rep 2,749
sunroof drain pipes got clogged by time
http://forums.bimmerforums.com/forum...Leak-from-roof
08-05-2014, 12:10 PM | #11 |
251
Rep 1,869
Any one know if I can swap a stock a amp without recoding?
08-11-2014, 11:18 PM | #14 | |
251
Rep 1,869
08-12-2014, 12:21 AM | #15 |
1911
Rep 13,104
Matching the amp number is the direct route.
Matching the amp part number is the direct route.
The Logic 7 amp for the 3 Series has the same specs from 06 to 09 I believe that's what you said you had right? You could also look on RealOEM for a part no if you can't read the one off the broken amp you have. Also FYI the part no's are in the following link http://www.bmwgm5.com/Logic7.htm The amp you were showing in the your pictures is logic 7 and not Hi Fi . Logic 7 is also called Top Hi Fi Dsp but its way different than Hi Fi. Last edited by ctuna; 08-12-2014 at 12:54 AM.. |
08-12-2014, 12:13 PM | #16 | |
251
Rep 1,869
08-12-2014, 02:46 PM | #17 |
1911
Rep 13,104
I would read that list and find the exact part no
I would read that list and find the exact part no for your model year
as long as you get a good one and nothing else is damaged you should just be able to plug it in . That's pretty much all I have to say. It looks like 09 is a different part no. although there is no reports of a change for that year. |
08-25-2014, 02:33 PM | #18 |
251
Rep 1,869
I had my car diagnosed. The problem is that there is a trunk seal that is bulged and is the cause of the leak. I am quoted 1855.34 to fix it. However i am getting it reimbursed from the shop that did not seal my trunk correctly. They are going to write me a check.
My question is, can i order the amplifier online (new OEM) and bring it into the dealership to have it installed, or will they refuse? |
