Boost pressure and ambient temperatures
12-15-2007, 03:46 PM | #1 |
Moderator
270
Rep 4,481
Hi,
Does boost pressure raise with ambient temperatures. Concrete, if a PROcede V2 user now sets user torque settings for a 15psi tune ( 94% ), will this user see more than 15psi on hot summerdays ? Or is it the other way round. Colder ambient temps, more boost. This would be logical, because the air is more dense. The question is what does the ECU / PROcede V2. Thanks, Eugen Last edited by e.n335; 12-15-2007 at 04:27 PM.. |
12-15-2007, 06:19 PM | #4 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Not quite. We've mapped the boost table to be somewhat self corrective below a certain User TQ value. Meaning that it will harder to induce boost pressures over 15psi even ambient temps were to increase significantly. Not something I've mentioned because I don't want people arbitrarily jacking up the numbers and thinking that they wont run any more than 15psi.
Shiv |
12-15-2007, 07:19 PM | #5 |
258
Rep 475
So, if ambient temp is high, say 90, you will see higher boost than at 50 degrees?
I remember seeing the opposite with my RX-7..... If boost pressure is higher at higher ambient temps, why is the car faster when the weather is cool? I suppose when I get my v2, I should set the TQ in warm/hot weather. |
12-15-2007, 07:21 PM | #6 | |
137
Rep 6,608
12-15-2007, 07:22 PM | #7 | |
137
Rep 6,608
Here you go..... (see I listen to you Shiv..)
12-15-2007, 07:24 PM | #8 | |
1737
Rep 17,960
Drives: A Lot
Unlike the BMW, the RX-7 didn't lower boost pressures are air density went up (to compensate for the mass airflow reduction). In fact, it effectively did the opposite which caused the car to run nearly a full point leaner. Combined with hot temps which reduced knock resistance, and the tendency of boost pressures to spike during single to dual turbo transition, the engines went BOOM. Of course, having a fragile engine that wouldn't take even one solid ping didn't help matters either. Great car. Crummy motor. shiv |
12-15-2007, 07:28 PM | #9 |
ocasionally in crisis
52
Rep 2,358
sorry to hear that... but our cars are pretty smart correct? the ecu will not allow overboost that would cause engine failure correct ? (unless your ecu tune screw up).
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
12-15-2007, 07:44 PM | #10 | |
1577
Rep 3,888
