The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Need advice on under seat subs
      07-29-2014, 03:03 PM   #1
mikeyraw215
mikeyraw215's Avatar
42
Drives: 2006 bmw 325i (e90)
I wanted to know if I can run my under seat subs as a dedicated mid bass woofer. Also what frequency range will they play flat at......
Also thinking about upgrading to these in the future
http://www.helixhifi.com/products/pr...item_id=599212
*TEAM SKAR AUDIO*
* Broadway Static coilovers with upgraded swift springs * M3 front control arms & rear guide rods * GodSpeed adjustable toe arms & camber arms * Forgestar cf5 18x10 & 18x12*
      07-29-2014, 03:46 PM   #2
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
sure can - try bandpassing from 80 to 200, they will welcome the unburdening of not playing sub 80. Then LP your sub at 80.
      07-29-2014, 03:52 PM   #3
kaigoss69
kaigoss69's Avatar
300
Drives: '08 335i
It would help to know what system you have...
If base, I wouldn't recommend it. If HiFi or HK, you can do it as already suggested.
There is a MB Quart 3-way system available for 500, including door speakers, tweeters, crossovers and underseat woofers. Plug n play.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
      07-30-2014, 03:22 PM   #4
mikeyraw215
42
Koo thanks. My amp is great for active set ups so I'm able to bandpass it. I'm gonna try that today to see what it sounds like
*TEAM SKAR AUDIO*
      07-30-2014, 03:25 PM   #5
mikeyraw215
42
Hifi..... and do u know if mb quarts sells just the underseat woofer. I already upgraded my 4" mids and tweeters are on the way.....
*TEAM SKAR AUDIO*
      07-30-2014, 07:10 PM   #6
bmw325i
223
Drives: 2006 BMW 325i
If you have a trunk sub you want the underseats playing from around 50-60hz up to around 200hz, and the trunk sub should play from 50-60hz down. Jehnerts are a good option if you're only using them for midbass.
      07-30-2014, 07:53 PM   #7
kaigoss69
kaigoss69's Avatar
300
Drives: '08 335i
Why not use the OEM woofers? They reportedly do very well with some added, responsible power.
      07-30-2014, 08:00 PM   #8
ctuna
1911
Drives: 325xi 06 wagon MT
Another vote for Jehnerts
They are a true audiophiles speaker in the 8 inch size
xe 200's that is.
      07-30-2014, 08:18 PM   #9
mikeyraw215
42
Yea i have a truck sub so I was wanting to use the underseat woofers for a dedicated mid bass woofer so I can cut out some of the midbass from my 4" mids. Also just wanted to see how high they can play flat to. So 200hz is no problem for them, how bout the jehnerts woofers, how do they like to be xover. I'm guessing the same...... thanks for the info
*TEAM SKAR AUDIO*
      07-30-2014, 08:21 PM   #10
mikeyraw215
42
I am, they sound pretty good for what they are and it gets the job done. Just wanted to know how high they play flat till. I just tuned the amp and eq 2day and it sounds great.....
*TEAM SKAR AUDIO*
      07-30-2014, 08:24 PM   #11
mikeyraw215
42
xe 200's that is.
Thanks man..... I'm gonna look into those, seems like everyone's choice. I feel like I'm gonna Def need an aftermarket choice after I install my new trunk sub, Def gonna be a lot more power and I'm tuning the enclosure at 30hz so I'm gonna need that midbass for sure.....
*TEAM SKAR AUDIO*
      07-31-2014, 05:03 PM   #12
joeyc123
Drives: 2007 328i
Try the OEM's first
Hey man,
Before you make the plunge in buying the jehnerts, I would totally try amping up the OEM woofers first. I know the opinions of everyone about jehnerts, and there is nothing bad to say about them at all! So don't get me wrong. All I'm saying is, I really don't feel a need to have better midbass after powering my OEM woofers with 100 watts of clean power. The only reason I would purchase jehnerts for myself is due to the curiosity.
      07-31-2014, 06:28 PM   #13
mikeyraw215
42
Originally Posted by joeyc123 View Post
Hey man,
I am powering the oem woofers with a clean 125 watts each but I had them running as subs cuz I sold my trunk subs to upgrade and change up my set up. I tuned the amp yesterday to see how they play as a midbass woofer and it sounds pretty damn good. I didn't think they would play up to 200hz clean. Just getting ready for my trunk sub so I figured let me try to use the underseat woofers as a midbass instead of not using them at all, like I was with my previous trunk set up...... thanks for the info tho man, I prolly won't end up upgrading at all. I doesn't feel necessary ATM.
*TEAM SKAR AUDIO*
      08-18-2014, 10:56 AM   #14
joeyc123
Drives: 2007 328i
Glad ya ended up liking it. They are pretty well built woofers and I have been pushing em with more and more power as well, as long as they don't go tooo low (probably below 80hz) they could stay safe with a ton of power. What kind of trunk sub setup are you planning on?
