2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Condensation in headlight?
      07-29-2014, 09:04 AM   #1
th1rd3y3
31
Drives: '20 M340i xDrive
Question Condensation in headlight?
Anyone have any issues with condensation in their headlights?
I've had the car since April with no issues, but yesterday morning I noticed there was a ton of condensation on the inside of my passenger side headlight. I'm going to make a quick visit to the dealer on my lunch break today to see if they can suggest what to do with it.
      07-29-2014, 09:38 AM   #2
m1cism
Drives: BMW 228i
I definitely would have them take a look at the headlight manifold. Try to push for an inspection of all the gaskets/seal or to replace them.
Since you have condensation, it may result in corrosion which then leads to malfunctioning headlights.
      07-29-2014, 10:29 AM   #3
Uridian
Uridian's Avatar
42
Drives: E36 M3, 228i M Sport
The night I picked up my car, it was cool out and I had condensation in one of the headlights. I mentioned it to my sales guy who told me it was normal. "Um... no it's not. I'll make an appointment to come have it fixed later".
Though, while reading the manual some days later, it does mention that it is normal to have some level of condensation in the headlights under certain circumstances. It's only if it doesn't go away does it become a problem. Sitting over a dewy night seems prime for a little condensation.
I wouldn't worry about it unless it sticks around all day or gets worse.
From the owner's manual:
"Condensation can form on the inside of the ex‐
ternal lamps in cool or humid weather. When
driving with the light switched on, the conden‐
sation evaporates after a short time. The head‐
lamp glasses do not need to be changed.
If the headlamps do not dim despite driving
with the light switched on, increasing humidity
forms, e. g. water droplets in the light, have the
service center check this."
      07-29-2014, 10:34 AM   #4
th1rd3y3
31
Ah good info, the condensation has been there since yesterday morning. I haven't driven with the the headlights on other than the DRLs which I'd imagine wouldn't generate enough heat to disperse any condensation.
The dealership is a about 15 minutes away so I'll turn the headlights on and see if it goes away like that before getting there. I do find it odd though that one would fog and the other wouldn't. While I didn't look closely this morning, it did look like there were actually droplets forming on the lens not just simply fogging.
      07-29-2014, 11:10 AM   #5
ska///235i
***** noob
ska///235i's Avatar
1368
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
If you look closely I think there are two tiny holes on the headlights...or maybe they are just marks that look like holes???
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      07-29-2014, 12:34 PM   #6
th1rd3y3
31
Well the service advisor thought it was bad enough to order a new headlight. Now to see how long that takes.
Pic for reference, it's actually worse than I thought it was.
      07-29-2014, 12:57 PM   #7
m1cism
Drives: BMW 228i
Yeah that looks pretty bad. And does your other headlight do the same?
If not, then there is something funny about this particular headlight
      07-29-2014, 12:59 PM   #8
th1rd3y3
31
Other headlight looks new, which is why I questioned it at first. After getting to the dealer and looking closer at it, I realized there was no way there was not something wrong with it. Service advisor obviously felt the same way as he took a photo of it and said they'd order a new one.
      07-29-2014, 01:10 PM   #9
m1cism
Drives: BMW 228i
Okay cool, glad you got it worked out. Let us know how it turns out.
      08-05-2014, 07:09 AM   #10
th1rd3y3
31
Just an update. Dealer actually got the light in pretty quickly and swapped it out yesterday with no issue. Hopefully this it the worst issue I have with this car.
      01-24-2015, 03:44 AM   #11
ACDV228i
17
Drives: 2014 228i Sport Line
does this apply to headlights only? ive had a lot of condensation in my tail light housing..
      01-24-2015, 04:46 PM   #12
th1rd3y3
31
Can't hurt to ask your dealer about it. From what I can tell a small amount isn't exactly abnormal, but if you're seeing a lot I'd at least see what they can do.
      01-24-2015, 08:52 PM   #13
zipphreak
No_Country
454
Drives: m235xi
http://www.ricart.com/blog/2013/augu...-headlight.htm
      01-29-2015, 02:20 AM   #14
Ace604
11
Drives: 2019 M2C
I've had mild condensation in my taillight before. Just take it to the dealer and they will sort it out. They swapped in a new tail light for me and said the new one is an updated design.
      01-29-2015, 02:56 AM   #15
mvallido
mvallido's Avatar
Philippines
70
Drives: M235i Estoril Blue
Customer service at it's Best.
2014 M235i {Dinan P1 Power Package}
2015 F30 320i
2006 E90
2004 C240
97 E39 VF5 Supercharged
2addicts
