max rear camber on stock rear arms
07-26-2014, 03:37 PM | #1 |
397
Rep 1,204
I was wondering what is the max negative camber we can go on stock arms? I recently got an alignment and the most they could give me was -1.8 in the rears which was odd because those are stock numbers.
07-27-2014, 08:30 PM | #6 |
851
Rep 2,771
Yea. The 1st mechanic I took mines to did the same thing. Maxed out my toe by turning the wrong bolt. Then I showed him a diagram that Tee had posted in the Aggressive Fitment thread highlighting the correct bolt to turn for camber. He got it right after that. Went from -1.8 to -2.8. 1 side went to -2.97 but the other side couldn't match it so I just stuck with the -2.8.
07-27-2014, 09:08 PM | #7 |
Where'd my VTEC go?
481
Rep 6,067
-2.8 here as well
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
07-27-2014, 09:55 PM | #9 |
560
Rep 5,367
ya everyones maybe a lil dif. pending on control arm bushing sagging over age/abuse/usage/mileage which explains some ppl reporting from -2.4 to -3
I maxed mine at -2.4.-2.5 when it had about 9k on the bushings. im sure it increased over the years of use.
You can follow my builds on IG: Tee212 |
07-27-2014, 10:59 PM | #10 | |
397
Rep 1,204
