Led headlight bulb
07-22-2014, 07:28 AM | #1 |
Rep 27
Led headlight bulb
Hi,
i was searching around and could not find whether people have tried changing their low beam halogen to led bulb that has a fan on them (instead of HID) so i thought i would ask, has anyone tried something like below? It looks better than halogen but not as bright as HID however low initial current draw. Although i am not sure if the cover on the back of the headlights could close due to the fan/heatsink.. Something like this http://pages.ebay.com/motors/link/?n...092805&alt=web Thanks in advance.. |
07-22-2014, 11:42 AM | #2 |
BimmerPost Supporting Vendor
471
Rep 4,938
I would highly not recommend to use those for On-Road use, especially as a low beam. Headlight reflectors are designed to focus on a specific spot on the headlight bulb. This LED kit will not have the same focus point and most likely will lead to light shining everywhere. This is why HID Kits are illegal in halogen headlights as well
07-22-2014, 02:40 PM | #3 |
99
Rep 198
Really depends on the housing itself and it's design. Every reflector type headlight is different. A friend of mine has an E30 track car that she randomly drives on the street. She put a similar kit into the H4 of that and it works really well. I was surprised. Almost zero glare too. It's a euro H4 style for E30.
07-22-2014, 03:20 PM | #4 |
Rep 27
Yes, i am concerned about glare hence not thinking of HID. But i thought these type of LED have the same spot as halogen light output so perhaps it would not create glare. And wondered if anyone have tried them and verify if there was glare or install issue.
07-23-2014, 02:23 PM | #5 |
1905
Rep 6,968
I would not spend 79.00 on 5000k only to blow a light bulb code either now or 6 months down the road when the resistor wears out.
Look into Philips Diamond halogen bulbs. You will get 5000 k for a fraction of the price |
07-26-2014, 06:31 PM | #7 |
Rep 49
DO NOT get these for headlights. There are ZERO LED "headlight" systems on the market that are even remotely close to having the correct optics for low beam headlight use. You are much better off with an HID system.
There is so much mis-information and false advertising for the aftermarket lighting industry. |
07-31-2014, 01:10 AM | #8 | |
99
Rep 198
07-31-2014, 11:50 AM | #9 |
Rep 49
Indeed it is highly dependent on the housing, but the light source is so far off what a halogen filament is, it will either:
A: Put a lot of light in places it should not be if its a reflector housing (above the cutoff) B: Most of the claimed light output will not make it onto the road if its a projector housing. Even if the cutoff appears to be sharp, most of the light never makes it out of the housing since it bounces around so many times in the incorrect orientation. Also, the beam pattern will still not be focused the way it should. For fog lights it tends not to matter as much, but the beam pattern will still not be anywhere close to what it would be for a halogen or HID bulb. |
07-31-2014, 12:03 PM | #10 |
471
Rep 4,938
a 1 or 2mm difference in the focus point of the bulb will make a Huge impact on the light pattern.. i would highly suspect that the LED would be more then 1-2 mm difference of its focus point.
07-31-2014, 12:34 PM | #11 |
Rep 49
You are correct, the position of the source has a huge impact on what comes out of the headlight. One thing to consider is that a halogen bulb has a coil filament abour 1.5mm in diameter and 5mm long. It produces a radial emission pattern from that coil.
All of these LED "headlights" on the market have these massive 10mm or larger diameter COB emitters facing only 2 directions. Not only is the emitting surface several orders of magnitude more than a halogen filament, its emission not in a radial configuration. I have many many hours trying to design an LED headlight that would match the optics of a halogen bulb and be at least 2x as bright. Only after tons of work did I realize I was battling a physics problem called etendue. http://en.wikipedia.org/wiki/Etendue Unfortunately at this time LED technology is not at a point where the lumen density is high enough to get enough light in the right direction and meet SAE low beam emission pattern regulations. I have tried countless things, some of which came close, but just would not cut it for beam pattern or brightness. |
