Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Put in wrong oil! Please help!
      07-20-2014, 04:38 PM   #1
Hydro
Hydro's Avatar
27
Drives: F22 M240i 6MT
Hi, today I changed my oil. I accidentally put in 5w-20 oil in instead of my usual 5w-30. I have no idea how I overlooked that. I've changed my oil countless times, but I guess I wasn't paying attention and bought the wrong oil. :'(
Is it so terrible for my engine that I can't wait until wednesday to change my oil again? I have to get to work and back monday and tuesday and I'm afraid it might harm my engine.
F22 M240i 6MT
      07-20-2014, 04:40 PM   #2
E92-N54
Drives: BMW 335i
You should be fine. I wouldnt worry too much.
      07-20-2014, 04:43 PM   #3
ryanakata
Drives: '11 e92 335i AT
I am not speaking these as the gospel and truth, but...
You will 99.9% likely be fine. There are many people who don't even change the oil and drive 30,000 miles on one change.
You put in new syn 5w20? As long as it is syn, it should be able to handle the high heat of these engines just fine. As long it as a syn, I wouldn't worry too much, drive it easy until you can get the right stuff in there. The odds of causing excessive wear are slim to none.
Good luck
2011 335i Coupe M Sport: Alpine White
      07-20-2014, 04:43 PM   #4
Eat.Sleep.Race
Out Boosting...
242
Drives: F30 335i M-Sport
You'll be fine
      07-20-2014, 04:43 PM   #5
Supra2k6
132
Drives: 335i
You will be fine no big deal really if you wanna run 5w-20 it wont harm the engine. No oil will harm the engine and thick oil will maybe give a vanos code if i'ts really thick. You should be fine.
      07-20-2014, 04:45 PM   #6
Hydro
Hydro's Avatar
27
Good luck
Ya, it is full synthetic Castrol Edge.
F22 M240i 6MT
      07-20-2014, 04:47 PM   #7
ryanakata
I'd hate to waste all of that oil. It would be tough for me to run a full OCI on it even though it would likely be fine.
If possible, drain into a clean pan and use in something else, someone with a Honda or something could get 2 changes out of it, lol.
I'd keep your same filter in there, a little 5w20 mixed with it will not hurt a thing.
      07-20-2014, 04:58 PM   #8
kautiongsr
bigdaddyjulio
kautiongsr's Avatar
12
Drives: 2011 E92 335IS, 2011 S1000 rr
don't waste you money.. keep same filter and just drain and add oil.. 7 quarts and done..
honestly even if you left if alone nothing would happen.. especially for a daily driver...
Big Daddy Julio
      07-20-2014, 04:58 PM   #9
gray boy
Drives: 2011 328ix
lifters might leak down a bit but if no noise from that you have nothing to worrrrrry about
      07-20-2014, 04:59 PM   #10
rick100
551
Drives: 328
engine will be fine. I've gone from synthetic to regular oil in my old car and the car still runs strong after 100 000 miles.
If you want to be extra care full, I would just drive the car easy the next 3 days but again you are fine
Most people would just leave it but I m the same as you
      07-20-2014, 06:08 PM   #11
GB-335xiCoupe
Libertarian
GB-335xiCoupe's Avatar
132
Drives: 29k mi per year.
You're fine, just put in your normal stuff the next time you do a change.
By the way, a HUGE mistake, would be something like filling your tank with diesel. Or using your sock to plug the oil fill hole.
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi
Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k
Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k
      07-20-2014, 07:12 PM   #12
Dark_Knight_335
Came to the N55 Darkside
Dark_Knight_335's Avatar
1112
Drives: 2011 335 E93 M-Sport
Or putting oil in your coolant reservoir. Didn't someone make a thread about that awhile back?
      07-20-2014, 07:19 PM   #13
e90Cam
e90Cam's Avatar
30
Drives: e90 LCI
Don't worry about it, just like everyone on here said. You'll be fine!
If you want to be safe have an oil change after 5000km, although every oil change should be around 5000km.. Stop worrying!
      07-20-2014, 07:37 PM   #14
parabola
parabola's Avatar
30
Drives: 2015 VW GTI
Turbo or non- turbo engine?
Correct oil viscosity is little less critical on naturally aspirated engines...either way you're OK until next oil change.
One of my previous cars had 2.0L 4-cyl engine with 8 valves (outdated by all means) and I put all kinds of oil in, cheap, conventional, synthetic, wrong viscosity etc...never seen anything go wrong related to oil use for 130k+ miles.
      07-20-2014, 07:56 PM   #15
evoix
441
Drives: X3m Evo IX Evo X
not a big deal. DOnt sweat it if your gonna change it this week
      07-20-2014, 08:00 PM   #16
anti1ne
Drives: 2006 330i
If you're pushing the vehicle to it's most absolute limits, then it would matter. Normal DD, you'll be ok.
      07-20-2014, 08:13 PM   #17
007_e350
007_e350's Avatar
217
Drives: 335i 2008 MHD'd / x5d E70
Id drain and put in 5w 40 if ure a high mileage engine
      07-20-2014, 08:34 PM   #18
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
If it was winter I would just leave it there until spring, but since you are in TX in july, I'd change it as soon as practical. It won't cause issues right away, you can run on it for some time.
      07-20-2014, 11:58 PM   #19
krhodes1
1436
Drives: 2011 328i Wagon
2011 128i  [10.00]
2011 BMW 328i Touring  [10.00]
Please keep doing this - my stock in Mobil Oil thanks you! Changing the oil every 5K KILOMETERS is hilarious in a car that has an oil life algorithm, an actual oil quality sensor, AND holds well over 7 liters for the express purpose of extending the OCI.
Where I the OP, I would not sweat a few 1000 miles on too-thin oil, but I would not beat on the car either, especially in TX in the summer. If you still have warranty, I would suggest changing it ASAP, but I agree with those who say don't bother to change the filter again.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option
'11 128i Convertible - Space Gray on Savannah Beige, 6spd manual,
also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire
      07-21-2014, 05:05 AM   #20
BashShah
296
Drives: 2012 335i Sedan
OP, according to your profile, you have a 335i.
So you have been using 5w30.... Great.... But oEM is 0w30 castrol SYNTECH.
What made you change it from OEM to 5w30?
DN
      07-21-2014, 03:16 PM   #21
fazman
681
Drives: 335 e90
Time to junk the car, u broke it!
j/k... honestly you will be fine with that oil... but I wouldn't push the car more than normal daily driving. If you really want to put in good oil, go to WalMart and pick up two 5 qt jugs of Mobil1 0w-40 Euro formula oil (LL-01) for $22.50/jug and toss in 7 qts of that oil. Your car will run smoother and run at least 10*F cooler oil temps.
It's best to change the oil on these cars at the 7500 mile mark or the 10k mile mark. You can actually hear a difference in the way the motor sounds.
- Faz
      07-21-2014, 08:51 PM   #22
Hydro
Hydro's Avatar
27
DN
OEM is actually Castrol 5w-30. I work at a BMW dealership and that's all we use.
F22 M240i 6MT
