Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      07-20-2014, 12:07 AM   #1
joeyb26
282
Drives: 2020 M340i xDrive
Odd grinding noise
So i have about 650 or so miles on my F80, and it seems that whenever the car sits overnight or sits for a day, whenever i start it up and start driving it makes a really weird grinding noise usually at low speeds, sounds like im grinding gears, but i'm not. seems to be coming from the right side of the car, i think towards the rear. anyone else experience this?
      07-20-2014, 12:23 AM   #2
GBPackerfan1963
39
Drives: 2002 BMW M5 2007 E60 550i
2002 BMW M5  [0.00]
rut-roh! Another diff failure?
      07-20-2014, 02:59 AM   #3
RickMonet
RickMonet's Avatar
175
Drives: 2015 M3 6MT
.... sounds like im grinding gears...
Yikes! Not a pleasant sound. That doesn't seem right - if it is repeatable take it in first thing Monday.
      07-20-2014, 06:39 AM   #4
dhoggm3
dhoggm3's Avatar
269
Drives: 850i C, Gated R8 5.2, E63
Sounds like the diff. Does it only happen when turning? M cars of the past have made "grinding" diff noises on slow turns , and it was considered "normal".
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune
Alpina B8, zero performance mods
      07-20-2014, 06:48 AM   #5
/// M sa
/// M sa's Avatar
241
Drives: F80 MG
Take it in ASAP your rear diff is failing and if it fails all the way the wheels will lock up on you. That is exactly what my issues was, it sounds as if your rubbing (tires) or even something is stuck in the break pads.... Also it will take about 3 weeks to get the part from Germany. Have them drain the fluid and it will be dark with shit load of metal particles in the fluid.
      07-20-2014, 06:59 AM   #6
JoeFromPA
1795
Drives: '15 AW M3 6MT Stripper
If it's a pulse grind that doesn't come back, it's ABS doing a test cycle.
If it's your diff, it will happen all the time in that given situation.
People on here tend to assume something is broken when given an incomplete description. Please explain more.
      07-20-2014, 07:08 AM   #7
/// M sa
/// M sa's Avatar
241
Drives: F80 MG
My diff was going bad and it made the noise at low speed and turning and it went away at high speeds.
      07-20-2014, 07:33 AM   #8
Wah
IG@i.am.wah
Wah's Avatar
2779
Drives: M2 CS
The E9x M3 had an issue with a noisy diff when turning at low speeds. There was a service bulletin to replace the diff fluid with a different one, which corrected the problem. I don't know if this is the same thing, but just saying that a noisy diff doesn't necessarily mean that it is failing. I hope it turns to be nothing.
      07-20-2014, 07:40 AM   #9
/// M sa
/// M sa's Avatar
241
Drives: F80 MG
BMW only now replaces them per dealer. BMW won't allow the tech to even open the diff and it has to be completely replaced.
      07-20-2014, 09:19 AM   #10
onatuesday
157
Drives: Hyundai
I wouldn't characterize diff grinding noises as "normal". It's not supposed to make that sound. Did many e46+e9x Ms suffer from that noise? yes. But mostly well into the life of the car not within the first 1000 mi. As mentioned usually changing the diff fluid did the trick but not always. IMO, the only acceptable drivetrain noises one should hear from a $70k car should be when you are putting the transmission into gear. Hopefully this is NBD but better bring it in to be safe rather than sorry.
      07-20-2014, 12:18 PM   #11
Stevens21234
114
Drives: F80 + 991.1 GT3
Shit, this model year sounds like a disaster
      07-20-2014, 12:20 PM   #12
GBPackerfan1963
39
2002 BMW M5  [0.00]
Yep......everybody cancel your orders and take your cars back. We have a travesty in the making.
      07-20-2014, 12:22 PM   #13
Sir Loin
M3AT LOVER
Sir Loin's Avatar
322
Drives: Silverstone F80 M3
Hey Joeyb26, would you please click the link below to go to the options and packages survey thread and submit a survey entry to the survey for your new car? Thanks.
http://f80.bimmerpost.com/forums/sho...d.php?t=999667
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
      07-20-2014, 12:23 PM   #14
Lups
Lups's Avatar
11825
Drives: I don't own a car.
This forum messes with the statistics so good. And since we write most about the fails, now all we can spot are those. Let's wait for the numbers before crying ourselves to sleep every night. I'm pretty sure we don't get the same picture as can be seen from them.
Originally Posted by Joekerr View Post
You're still a little new here, so I'll let you in on a little secret. Whenever Lups types gibberish, this is an opportunity for you to imagine it to be whatever you'd like it to be.
Originally Posted by Delta0311 View Post
How would you know this? Did mommy catch you jerking off to some Big Foot porn ?
      07-20-2014, 12:28 PM   #15
Wah
IG@i.am.wah
Wah's Avatar
2779
Drives: M2 CS
She speaks the truth...
      07-20-2014, 12:35 PM   #16
SakhirM4
SakhirM4's Avatar
10785
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
Guess that will leave more F8x cars for those who really want them.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
eunosracr157.00
      07-20-2014, 12:38 PM   #17
Zero4910
///Mmmm Good!
Zero4910's Avatar
12
Drives: 2015 M3
I agree. Does nobody remember reading all the I///M Delivered, EU delivery, and regular delivery reviews? We've seen what, 2-3 rear diffs, 2 seat logo noise, 1 A/C issue, and some other minor negative/problem reviews.
So a handful of issues vs nothing wrong from the several other hundred(s) of M3/4 from all the press reviews, YouTube reviews, and magazine write ups.
I feel for the folks who have had issues, but so far the number of good vehicles far out way the bad.
That being said, I pick up my M3 tomorrow and now I'm going to have every issue I just mentioned.....I'm starting to sound like you Lups.....I have to quit these forums
2015 ///M3 F80
[ Black Metallic Sapphire | Black Ext. Merino Leather | 18" Silver-Light Alloy Wheels | 6 Spd Manual Transmission | Carbon Fiber Trim| Driver Assistance Plus / Executive | Adaptive M Suspension | Moonroof / Harman Kardon Surround ]
      07-20-2014, 12:44 PM   #18
/// M sa
/// M sa's Avatar
241
Drives: F80 MG
Every car maker will have some issues go wrong with some of their cars. It's a numbers game, sucks for me to be part of that statistic with a faulty rear diff.
      07-20-2014, 01:00 PM   #19
Sir Loin
M3AT LOVER
Sir Loin's Avatar
322
I recommend we start these threads below:
- M3 accelerates too fast when throttle pedal pushed down, jerks my head
- Warm (and then HOT) air comes out of exhaust pipes after starting car, doesn't go away until after car is turned off
- Gas tank drains quickly after only driving 300 highway miles, is there a hole in my gas tank?
- left turn blinker seems to blink 20ms faster than E92 M3, extremely annoying!
- No sunroof on my Carbon Fiber roof, SA screwed me?
- Manual transmission missing 7th gear, worst transmission evar!
- excessive wind noise when only one window glass is rolled down, even at only 50mph
Appreciate 2
      07-20-2014, 01:03 PM   #20
/// M sa
/// M sa's Avatar
241
Drives: F80 MG
Lmao
      07-20-2014, 01:06 PM   #21
tooch
112
Drives: F82
96 E31 JB
07 E92 AW
F82 BSM
      07-20-2014, 01:06 PM   #22
Lups
Lups's Avatar
11825
Let's just cry in the shadows when ours break down. I'm so sure this will indeed happen to me, I'm packing pregnancy tests, water bottles, food and of course a mechanic to my road trip. I know for sure I'm not pregnant, but just to make sure the story is the saddest one ever, I'll make him pee on the sticks when the car breaks down. I now am thinking how to come up with the job advertisement.
f80post
