ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      07-17-2014, 02:27 AM   #1
savaho
savaho's Avatar
39
Drives: M3
1200 mile service done, but Launch Control still inactive
Just got my car back from its 1200 mile service. I asked the SA if Launch Control (LC) was activated and he said that was taken care of when they did the pre-delivery checklist. hm... I doubt that but hey I'm not a service tech that should know what he is doing. I have been trying several times but I can't for the life of me get the LC to work. I disabled MDM/TC, select S1, 3 bars for sequential, step on brake and mash the accelerator. I'm able to peel off but car doesn't shift itself into 2 nor do I see the LC flag anywhere. Did the tech fail to reset the computer to enable LC properly or am I doing it all wrong? In my E92 M3 the LC flag would appear before you even step on the accelerator.
Hey BMW here's a tip - just incorporate an LC button that configures everything for the driver so that all he has to do is mash on the accelerator!
      07-17-2014, 02:46 AM   #2
04RC51
Large Member
04RC51's Avatar
951
Drives: E92 M3, F82 M4
Did you over and over or just do it like it was on the E9x?
2008 E92 M3 (Engine swap completed), 2015 F82 M4
      07-17-2014, 05:26 AM   #3
M5Rlz
249
Drives: R8, f10m59(Rip), m4, GTR
They have a detailed breakdown on how to do it on the manual stored in the car. I kept trying the way I did it on the m5. Now its:
1. drive till warm
2. traction off /s3
4. Brake with left foot+ mash on gas pedal which will now trigger the flag
5. set launch rpm with cruise control
6. Dont die
      07-17-2014, 06:41 AM   #4
mkoesel
Moderator
7509
Drives: No BMW for now
The process he is using is described in his post and it's nothing like the E9x M3.
OP, in the past LC was not necessarily active immediately after the 1200 mile service was complete. For the E9x M3, for example, it would often take until about 1250 miles. The F8x may be similar. How many miles do you have on the car now?
      07-17-2014, 11:43 AM   #5
M4TW
///M Uber Alles
M4TW's Avatar
332
Drives: '15 MW M4
Try starting in D rather than S1.
die Welt ist meine Auster
2015 M4, MW, Black Full Merino, DCT, CCB, Adaptive M Suspension, Premium, Executive. Technology, ConnectedDrive, CF Trim, Convenience Telephony, European Delivery
      07-17-2014, 11:44 AM   #6
Simon H
Simon H's Avatar
876
Drives: M5 Competition
Do you not have to hold the gearshift forward anymore, like the F10 M5?.
      07-17-2014, 12:30 PM   #7
mkoesel
Moderator
7509
That won't work - you have to have the transmission in the S3 setting.
Right, that's no longer part of the procedure.
Originally Posted by M6-Coupe View Post
For sure you know how to activate it because you had E92...
Except that the process is nothing like the E9x M3, and it is also different from the F1x M5/M6. If you read the manual you'd know that.
Edit: Here is the instruction.
It's completely incorrect. Surely you'd rather your post be removed than have it remain and create confusion, right? It's nothing personal - we just don't want to spread lies here.
      07-25-2014, 12:54 AM   #8
savaho
savaho's Avatar
39
Drives: M3
From the Owner's Manual:
Activate Launch Control
Launch Control is available when the engine is warmed up, that is, after uninterrupted driving of at least 6 miles/10 km.
1. Deactivate Dynamic Stability Control, refer to page 112.
2. Select Sequential mode with driving program 3.
3. With the engine running, apply the brake with the left foot.
4. Fully depress the accelerator pedal. The starting engine speed adjusts. A flag symbol appears in the instrument cluster.
5. If necessary, change the starting engine speed by 500 rpm via cruise control.
6. Release the brake, the vehicle accelerates. Continue to depress the accelerator pedal. Upshifting occurs automatically as long as the accelerator pedal is fully depressed.
Hints
Launch Control is available only after a certain distance has been driven. Did not use Launch Control during the break-in, refer to page 152, period. To maintain driving stability, always activate DSC if possible.
I can't get the flag to appear and I've given up. Every time I attempt LC I feel like I'm messing up the engine by redlining it.
      07-25-2014, 03:43 AM   #9
ss134
ss134's Avatar
230
Drives: F80 M3
Hints
Did you make sure the throttle is fully depressed ie all the way to the floor/kick down switch? Did you use the button by the shifter to turn off DSC or did you use an M1 or 2 button that was already preprogrammed as DSC off?
      07-25-2014, 04:45 AM   #10
savaho
savaho's Avatar
39
Drives: M3
Bounces off of redline instead of holding at 3K as expected. I tried both M1 w/DSC off and just DSC off. It's not a big deal. LC is something I probably won't use anyway.
      07-25-2014, 04:56 AM   #11
ss134
ss134's Avatar
230
Drives: F80 M3
Seems strange. How many miles are on your car and did you drive it for over 6 miles prior to attempting LC?
      07-25-2014, 05:30 AM   #12
savaho
savaho's Avatar
39
Drives: M3
I had approx 1300+ miles on the odometer and yes, I drove about 30 miles continuously before making the attempt.
      07-25-2014, 01:42 PM   #13
ss134
ss134's Avatar
230
Drives: F80 M3
If you've followed the instructions then I'm stuck. Only thing I can think of is try DSC off first via the button next to the shifter, then put into S mode and adjust up to S3 using the button by the shifter.
Maybe if you were already in S3 or had DSC off it doesn't compute that you want LC - maybe you have to change both settings one after the other before applying the brake and flooring the accelerator?
It's a long shot but worth a try.
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold
2010 JZB E90 M3 DCT - Sold
2009 6MT E90 LCI 335i M -Sport - Sold
      07-30-2014, 12:23 PM   #14
jackass
50
Drives: M5, 911 Turbo s
Any news? I got the same problem?
      07-30-2014, 01:15 PM   #15
savaho
savaho's Avatar
39
Drives: M3
OK I may not have been pressing the accelerator pedal down fast enough previously which allowed the revs to build up to redline. This time I immediately floored the pedal as far as it would go and it did hold at approx. 3.5K rpm but the LC flag still did not appear. I honestly think that LC is not activated. Someday I'll get it activated and working.
      07-30-2014, 01:55 PM   #16
01ON19
01ON19's Avatar
168
Drives: 2021 M2C
According to an F80/F82 training manual that was posted here, LC will not work unless the 2000km maintenance has been completed with "reset/confirmed with the Integrated Service Technical Application (ISTA) (do not reset via the instrument cluster service function, as otherwise the launch control is not enabled)."
The first thing I would do is check with the dealer.
      07-30-2014, 02:50 PM   #17
jackass
50
It works! U really need to hit the accelerator fast down!
      07-31-2014, 01:54 AM   #18
Wes Howell
www.facebook.com/weshowellcreative
59
Drives: 2015 AW M4 Coupe Project Car
Good to know. I have had trouble getting it to work too.
      07-31-2014, 03:52 AM   #19
ss134
ss134's Avatar
230
Drives: F80 M3
How was the launch now that you got it to work? LC has been very effective when I've used it.
2014 AW F80 M3 DCT
      07-31-2014, 07:00 AM   #20
jackass
50
I didnīt launch it yet...lol.
      07-31-2014, 10:16 AM   #21
ss134
ss134's Avatar
230
Drives: F80 M3
why not???
2014 AW F80 M3 DCT
      07-31-2014, 10:51 AM   #22
ss134
ss134's Avatar
230
Drives: F80 M3
For those of you that still cannot get LC to work after the 1200 mile service:
Read this thread: http://f80.bimmerpost.com/forums/sho...85732&posted=1
As Savaho eluded to in his first post it does indeed look like service tech error could be to blame.
Worth checking if your service history is now on I drive as well.
2014 AW F80 M3 DCT
f80post
