07-16-2014, 02:35 PM | #1 |
***** noob
1369
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
I know oil changes are all the same but has anyone done a diy oil change yet? Any trouble getting the m235 on ramps?
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
07-16-2014, 02:51 PM | #2 |
1399
Rep 5,262
I did one last week....
Ya I had to do some ramp extensions with some home depot 8x2 cause the bumper will not clear the ramp... you might be able to see it in the pic behind the metal ramp Also got an adapter to be able to remove the oil filter http://www.pepboys.com/product/detai...ilter_wrenches |
07-16-2014, 02:57 PM | #3 |
***** noob
1369
Rep 10,479
Looking good, i have the rhino ramps and have the woods ready...also already have the oil filter cap from previous e90 n52. Hope its the same size and if not I'll just bust out the strap wrenches
2006 325xi (Sold)
07-16-2014, 03:02 PM | #4 |
1399
Rep 5,262
just make sure if your car is in a down hill you put the ramps in the opposite way... so that the lift from the front ramps compensate a bit with the down hill so it's as level as posible...
my garage is downhill towards the rear of the car and when i lifted the front was even more pronounced so then when there is very little oil left it will start moving towards the rear of the oil pan and dripping some oil into the cloth cover of the undercarriage... |
08-21-2014, 09:59 AM | #6 | |
***** noob
1369
Rep 10,479
2006 325xi (Sold)
09-30-2014, 02:41 PM | #7 | |
13
Rep 89
09-30-2014, 02:51 PM | #8 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
# of quarts?
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
09-30-2014, 04:12 PM | #10 |
1399
Rep 5,262
09-30-2014, 08:53 PM | #11 |
13
Rep 89
10-01-2014, 04:03 PM | #13 |
3074
Rep 5,577
Did first oil change on 235. Unfortunately I could not get car onto Petersen Utra-Ramps with extension without rubbing the flexi-flap in front of the front tires. Resorted to my 3.5 ton Arcan garage jack (Costco) and a ReverseLogic pad (lifting point) tool.
I lifted at the drivers side front jack-point and was able to get enough height to work the flap door and drain plug. I was also able to lower the car to 'level' while draining to get a good drain. The one tool I purchased for the job that was indispensable the Form-A-Funnel [small size (green object in picture)] that routed the draining oil over the flap door into a basin. The factory drain plug gasket was silver and blended onto the drain plug bolt - so be sure to pry that off. The OEM filter kit came with a copper drain plug. And the actual factory filter was installed with the writing on the filter facing upward into the plastic filter cap. I purchased a OEM filter socket made in Switzerland. Used a 27mm socket to turn the filter cap. I put in around 6.6 quarts ( let drain for about thirty-minutes ) and after a short 1.8 mile drive car showed oil at 'MAX' level with a 'Oil O.K.' reading. And when under the car I placed a floor jack and spare tire strategically though not touching anything and I used two wheel chocks on the passenger side front & rear. The next time I do a thirty-minute drive I will chk oil level - the system needs that thirty minute drive for the iDrive oil level reading to be accurate/stated in manual. Last edited by overcoil; 10-22-2014 at 07:15 PM.. |
10-01-2014, 05:38 PM | #14 |
***** noob
1369
Rep 10,479
Any part # for the filter
I believe is the same as the n52/54/55
2006 325xi (Sold)
10-01-2014, 05:47 PM | #15 | |
3074
Rep 5,577
From my invoice :Part # 83300493936* Genuine BMW N52/54/55 Oil Filter Cap Removal Wrench But I'll chk the actual part when I get home. Some post mentioned how some cheaper oil filter sockets had deformed over time making use difficult, so decided to go with the OEM. |
10-01-2014, 06:11 PM | #17 | |
***** noob
1369
Rep 10,479
2006 325xi (Sold)
10-01-2014, 06:17 PM | #18 |
1399
Rep 5,262
I did mine and it was the same as the regular n55 whatever that one is
http://www.fcpeuro.com/products/bmw-...ilter-041-8195 |
10-01-2014, 06:49 PM | #20 |
***** noob
1369
Rep 10,479
Great thanks for the confirm
So these are the same for all N52/N54/N55 engine I get the filters from Mann HU816x (Mann is actually the oem supplier for these filters) and they can be found at around $8-9 (usd) The filter wrench can be found on amazon for $18 (AST V410) Oil (mobil 1 0w-40 european formula) can be found at Walmart for $23 (5 qt) jug As for ramps, i got myself some race ramps but if you have clearance issues, use some 4x2 to give you that extra 2"
2006 325xi (Sold)
10-01-2014, 10:59 PM | #21 | |
1399
Rep 5,262
it's $6 instead of $28 it's made of metal so no issues wearing off I rather use BMW oil so it's the same oil they use for the free oil changes.... http://www.fcpeuro.com/products/bmw-...-oilchgkit6327 but I don't really think using Mobil 1 would make any harm...but I rather just use the exact same brand... |
10-02-2014, 06:06 AM | #22 |
***** noob
1369
Rep 10,479
M1 0w-40 is LL01 approve
Used it 9 years on the e90 $6 is cheap metal vs aluminum and you have to add shipping no? Those wrench might not apply even pressure when you torque it...result in premature oil filter housing gasket wear. Just my 2 cents But whatever works
2006 325xi (Sold)
