2008 328i coupe (e92) Turning Right at Low Speed Squeak
07-16-2014, 01:44 AM | #1 |
Rep 10
Hi guys,
This is my first post. I have already done a search up for this issue but on many of the similar posts, they get hijacked with others clearly not reading the issue and talking about grinding etc ... So, the car is giving me a high pitched squeak sound while ONLY turning RIGHT at low speeds (less than 20km/h) and no brakes being used. If I apply the brakes the noise stops, and if I accelerate out of the turn it stops as well. This does not seem to be a braking problem, front brakes are brand new (rotors and pads from BMW about two months ago). I thought the sounds was because the front brakes were low and needed to be replaced but it still makes the sound even after they've been replaced. Has anyone had this exact problem and what was the reason? Thanks for your help! |
07-16-2014, 02:12 AM | #2 |
36
Rep 228
Drives: 2013 E92 Melbourne M3
I've got this also. Its really bad. Mine progressed from only happening when i turn right to ALL the time at low speeds. Its driving me insane. It goes away immediately when I apply the slightest amount of brake so I definitely think its related to the brakes.
07-16-2014, 11:37 AM | #3 |
Rep 22
guys,
first of all check your steering fluid and top it up if needed. some people suggested to use silicone spray in the steering wheel bay. i have not done those things yet myself since working on Valve Cover Gasket. as soon as i finish with it, will look into squeak/whistle noise when turning at slow driving. |
07-16-2014, 01:00 PM | #4 |
Rep 10
The sound is definitely coming from outside the car not inside of the steering column (sorry not sure where the steering bay is) and to me, appears to be coming from the front right wheel area. It also only happens when doing a tight turn.
As for steering fluid, the reservoir is mid level when I checked, the dipstick on the cap for the steering fluid reservoir has 3 levels - my level sits right in the middle of the 2nd one. I assume since the fluid level is smack dab in the middle of the 2nd level it is where it should be. |
07-17-2014, 01:38 PM | #5 |
27
Rep 292
My car does this as well, as do many on the forum. They haven't really found a fix but there's a good bit of suggestions and things that work for some on the forum. Here's a link:
http://www.e90post.com/forums/showthread.php?t=526765 |
07-28-2014, 01:17 PM | #6 |
1268
Rep 2,957
My car did this when I first bought it. At low speeds it was an annoying metallic squeeling noise that went away when I hit the brakes. For me it was the brake pad sensors. I also did a full brake job (rotors, pads, sensors) at the same time but it was def the sensor. Not sure why...
09-03-2014, 01:43 PM | #7 |
Rep 1
Brake Squeal / Squeak
Hello everyone, did you find the solution to this? I just took my 335i in for service with this issue today. The lead service technician said this is a common problem with the 330 and 335i models. As the breaks wear in they don't do so evenly, this causes an issue with the right rear e-brake shoes. According to him when the brakes warm up after 15 to 20 minutes of driving the noise will be most obvious especially at low speeds. He is completing an e-brake service and chamfering the edges of the shoes to solve the problem. I am crossing my fingers that this works as the sound is incredibly embarrassing as I squeak down the road at low speeds.
09-04-2014, 12:22 PM | #8 | |
36
Rep 228
