springs H&R v Eibach etc
07-15-2014, 10:23 AM | #1 |
23
Rep 523
have swapped the runflats for non runflats and although the car is slightly more comfortable i preferred the car with runflats as the handling (specifically sudden direction change)is...wallowy... much less precise than the runflats,i have played with pressure and this makes no difference,so,i either go back to runflats or swap the springs for something a little stiffer,i would prefer the ride height to stay the same but i cant find anywhere that does standard height stiffer springs and i would rather replace the runflats than buy coilovers....so....
whats would be a cure to my issue,H&R or eibach or does anyone have any other options,cheers |
07-15-2014, 10:35 AM | #2 |
21
Rep 413
H&R's go lower than Eibach's as far as I'm aware. So go for the Eibach's.
Edit: I also run non-runflats and Eibach and think the ride is very good. Not too stiff, not to soft. |
07-15-2014, 01:28 PM | #6 |
23
Rep 523
the backbreaking bit is not a problem (im used to owning skylines etc) but the low ride height would bother me,out of interest how much stiffer over standard M-sport suspension will eibach be
07-15-2014, 01:40 PM | #7 | |
Senior Troll
224
Rep 3,378
I would opt for shorter bump stop if you going for that route. |
07-15-2014, 01:44 PM | #8 |
21
Rep 352
I dont have a problem with my H&Rs. Great looking drop, no problem with speed bumps, great handling. They are stiffer but i wouldnt say backbreaking by far.
07-15-2014, 01:52 PM | #9 |
413
Rep 1,286
I did a lot of research on this very subject before selecting the Eibach Pro Kit with the Koni FSD shocks. I wanted a ride quality very close to stock and only a small amount of drop, and I accomplished both with this kit. I'm still running the run flats but I'm curious as to which tires you installed? Also, before changing the springs, you may want to consider an alignment with a bit more negative camber, as this might help your problem.
07-15-2014, 02:16 PM | #10 | |
23
Rep 523
07-15-2014, 05:03 PM | #11 |
89
Rep 1,378
Ive had both, and H&R are lower, but also more bouncy.
My E91 has M Sport shocks with Eibach springs, and 19" wheels with no RFT's and the ride/handling is spot on. It also sits perfect too, lower than stock but not stupidly low to catch on speed bumps. |
07-15-2014, 05:49 PM | #12 | |
53
Rep 1,249
How much does an alignment cost?
E90 lci 330d, alpine white, pro nav, adaptive xenons, heated electric leather, folding mirrors, alpine retrofit kit with L7 subs, performance grilles, 40w led angel eye bulbs
07-15-2014, 07:11 PM | #13 | ||
53
Rep 1,249
07-16-2014, 08:44 AM | #14 | |
46
Rep 891
Black or Red? the ride height of yours is perfect, so wanting to get the right springs when i come round to buying some :P |
07-16-2014, 03:42 PM | #17 |
886
Rep 9,097
Eibach Pro= Black
Eibach Sportsline = Red which is equal to H&R. I had Eibach Sportsline on my last car and drop was too low. So I had to drive slow on the speed bump however grip and handling was way ahead of M-Sports. If I will do it again, I will go for Eibach pro. Drop is subtle initially but after 1-2 months you achieve reasonable drop without loosing the comfort.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
07-17-2014, 08:11 PM | #19 |
Senior Troll
224
Rep 3,378
Guys, i'm selling my used eibach pro springs for e92, check the classifileds if interested.
Thanks
Gone:
N54 335i is the Legend! N55 435i Now: 718 Cayman GTS / F83 M4 |
07-17-2014, 08:11 PM | #20 |
Senior Troll
224
Rep 3,378
how did you get the intake bit for the bumper sorted out?
Gone:
07-18-2014, 12:45 AM | #21 |
53
Rep 1,249
Ive just ordered a set of eibach pro's and will be fitting next week so if you aint sorted nothing by then il report back and let you know how she feels
07-18-2014, 02:36 AM | #22 |
21
Rep 413
