2010 2011 BMW 5 Series Forum F10 Remove small scratches from Black Paintwork |
07-15-2014, 07:21 AM | #1 |
Rep 13
First of all greetings, I'm new to owning a Beemer and new on here. I've just purchased a 2011 F11 520d M Sport in black (sales photos & 1 of my own included). However, it has a kerbed wheel in 2 places that I'm having professionally refurbished and a few scratches here and there which I'm contemplating having a go myself at removing.
You can see in the last 2 photos the worst of these on the tailgate, the top one you can feel bubbling under the paint, but the others are scratches in the clear top coat. Hence the white appearance. Any advice on how to tackle these would be helpful, as I don't want to wreck the paintwork any further and would like to purchase the correct tools and supplies for the job in hand! Also suggestions in keeping in tip top shape will also be generously received. Any help will be greatly appreciated and thanks in advance....... Last edited by F11pilot; 07-15-2014 at 08:51 AM.. Reason: After thought |
07-15-2014, 05:33 PM | #2 |
38
Rep 234
Go to this website....lots of videos and PDF downloads on techniques and equipment needed!
http://www.ammonyc.com under videos, you will find this one about correcting small dings and chips in black paint:http://www.ammonyc.com/detailing/paint-chip-touch-up/ Last edited by Monkey Punk; 07-15-2014 at 10:09 PM.. Reason: Found a specific link in there |
07-16-2014, 02:43 AM | #3 | |
Rep 13
Monkey says......this monkey does!
07-16-2014, 04:41 AM | #4 | |
38
Rep 234
Edit: Goes without saying, do it out of direct sunlight to keep paint and clear coat from gumming/clotting up on the job. Last edited by Monkey Punk; 07-16-2014 at 04:43 AM.. Reason: Forgot something |
07-17-2014, 08:16 PM | #5 | |
38
Rep 234
Last edited by Monkey Punk; 07-17-2014 at 08:17 PM.. Reason: grammar corrections |
07-18-2014, 02:51 AM | #6 |
Rep 13
Ammo NYC
I did, not sure about attacking the car with a piece of sandpaper stuck to a pencil, as not sure I have enough confidence in my skills without practice! I'm definitely going to have a go at swirl/scratch removal, but going to have to wait until I can afford the proper kit! However, I may take the easier option as I'm having one of the alloys kerb scuff damaged repaired professionally next month so I might just ask for quote to take care of the area in the 2 photos on the tailgate. But I'm purchasing the polishing and washing gear next month after I've been paid and see what results I get done by hand on the polishing.
07-18-2014, 03:02 AM | #7 | |
38
Rep 234
07-18-2014, 06:04 AM | #8 | |
Rep 13
Good call on the panel to practice......
Will do mate, all the best! |
07-18-2014, 06:47 AM | #9 |
285
Rep 634
Be careful as bmws factory paint is not very thick, using the right tool for too long and you will go through the paint.
As for the scratches, you will probably not be able to get rid of them completely, a good indication is what the area looks like when wet, that is usually the best you can get it with a proper polish. The bubbleing usually indicates rust, I would have had that repaired professionally, might get that on the factory warranty actually, dont they have a 5 year rust warranty? |
07-18-2014, 08:01 AM | #10 | |
Rep 13
BMW factory paintwork
Rather disappointing news about the thickness of paint, as I was under the impression that Germans do it better! But I'll make sure I go easy, thanks for the heads up. |
07-18-2014, 01:18 PM | #11 | |
285
Rep 634
Check my writeup here http://f10.5post.com/forums/showthread.php?t=1005257 All modern cars have just a few microns of paint, saves weight and cost. Used to work in the airline industry, to paint a boeing 737 added 300kg of weight |
07-18-2014, 07:54 PM | #12 | |
38
Rep 234
07-19-2014, 06:56 AM | #13 | |
285
Rep 634
I am not a pro, just an amateur when it comes to detailing, I do my own and friends cars. My pads are medium and fine scholl pads, but I was thinking about trying swissvax medium and fine pads next time. I have a friend who is, well, up there with the best, Paul Dalton level almost. He does all the exotic cars in my area. If you want to see. Here is his facebook page. You will find Porsches, Ferraries, Aston Martins, Morgans, Buggatis ect ect on that page. https://www.facebook.com/TommysCARSPA I use his advise when getting products, but since I am a novice I dont want to end up having to repaint a body panel because I went through the paint. Therefore I stick to medium treatment, which is enough to get rid of swirls, scuffmarks and holograms. And it will take care of most scratches as well. As I said, the paint is so thin on newer cars that I would not want to use something highly abbrasive without proper guidance. |
07-19-2014, 07:10 PM | #14 | |
38
Rep 234
07-20-2014, 06:40 AM | #15 | |
285
Rep 634
For us beginners, get a oscillating machine, a rotating machine is much more difficult to use. You will make holos with it, you can see the tracks from the machine in the sun if not done right. You can easily overheat the paint damaging it, and it is much easier to go through the paint on edges. With an oscillating machine you are much safer, its harder to damage the paint, or get holograms or tracks. I dont use a rotating machine, and I will probably not start using one soon either. |
