BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Can you pass NY state inspection with Catted Downpipe
      07-13-2014, 09:35 PM   #1
Dan Villa
Dan Villa's Avatar
No_Country
52
Drives: 2020 M340i X-Drive
2020 BMW M340   [9.75]
I cant seem to get solid answers by searching. I have read some get a CEL while others do not Anyone in NY have one installed with out any issues? If so which one?
Thanks
Dan
      07-13-2014, 10:03 PM   #2
j23a45m
j23a45m's Avatar
44
Drives: 2012 E70 X5
its hit or miss.
some say a o2 spacer on the rear sensor works to get you passed
2011 BSM 335i E90 MTECH 6MT • JB4 stage 2 iso 5.3 FF wire• BMS Intake • Vishnu DP • Cyba Scoops • LUX V4 • 6000K Headlight/Fog light Philips Ultinon • Euro headlight switch • ACS roof wing • 35% tint • Performance Grilles • Misc coding • Cobb charge pipe • ///M3 fenders • 335is pedals • BC Coilovers • Vrsf 7" IC • ///M3 mirrors •
      07-13-2014, 10:37 PM   #3
Jsoboti
Jsoboti's Avatar
28
Drives: 2011 335i E92 M-Sport 6MT
Thanks
Dan
Do you mean "catted" like it says in your title or "catless" meaning without a catalytic convertor.
Stock, all of our cars have catted downpipes and will pass inspection in that regard.
A Catless downpipe is a whole different story
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
      07-14-2014, 09:29 AM   #4
Dan Villa
Dan Villa's Avatar
No_Country
52
A performance catted dp not the stock one.
      07-14-2014, 10:15 AM   #5
Zombie1
172
Drives: BMW 135i 2010
no it wont pass.
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms
      07-14-2014, 11:02 AM   #6
glachhman
41
Drives: '07 335i e90
Do you have a check engine light for it? If you don't its fine.
      07-14-2014, 01:12 PM   #7
Dan Villa
Dan Villa's Avatar
No_Country
52
That's the obvious I want to buy one but don't the CEL. That's the whole reason for this post.
      07-14-2014, 01:13 PM   #8
Dan Villa
Dan Villa's Avatar
No_Country
52
Does anyone actually have one and has past inspection?
      07-14-2014, 03:30 PM   #9
Dan_Q
Dan_Q's Avatar
117
Drives: F80 M3, F15 X5 50i
2018 M3  [9.50]
2015 X5 xDrive50i  [10.00]
Have you checked out this thread? It looks the Wagner catted downpipe is able to avoid the CEL without issue both according to the poster as well as if you take a look at the Wagner website claims. I am also looking into getting one of these for these reasons.
Not sure what the protocol is in NY but in Colorado we need to pass both a sniff check and the diagnostics check. I gather that if you have no CEL then you're passing the diagnostics check. Once that is completed they rev the car up for about 5 min at all RPMs on a dyno type machine while analyzing the exhaust gas for passing CO and NO levels. In my experience with a high flow cat on my prior car (Audi) it passed with flying colors. The measured values were worse than it would have had if I were using the stock cat but still well below the allowable limits. I have heard the cat can degrade in performance over time and so it is possible that down the road they will fail after passing for multiple years but I've read no solid info on that.
So sorry that I don't have any solid info to give you but this may be enough to get a warm fuzzy that it will pass. The other people to call and ask about it would be AR Designs. They are located in Colorado and they make a catted downpipe too. I have no doubt that they will be able to give you some more concrete info on them. They made them for the N54 too so they probably have collected a lot more evidense on their ability to pass over time (or not). Let us know what you find out.
      07-14-2014, 03:38 PM   #10
335iFFM
23
Drives: 335i Performance
I've modded my OEM DP and past it ;-). 200cell custom cat
      07-14-2014, 06:08 PM   #11
Dan Villa
Dan Villa's Avatar
No_Country
52
Thanks for the info. In NY as long as you don't have a CEL your good to go.
      07-14-2014, 06:09 PM   #12
Dan Villa
Dan Villa's Avatar
No_Country
52
That's a damn good idea...is there a substantial power gain since there was no change in overall diameter of piping?
