E90 325i using oil !
07-13-2014, 01:15 PM | #1 |
111
Rep 716
I have just noticed that my electronic oil gauge had went from MAX to now one away from MIN. It has been 1800 miles and 6 month since I changed the oil and had it at MAX ( I do very little millage ). I read when it's at MIN you add 1 full litre so I have added 500ml but it hadn't moved the level still sitting in exact same spot !
My old car ( golf mk5 Gti ) used oil but this is widely known and accepted with that particular engine plus a lot easier to check the level as it had a dip stick. What should I do. I'm concerned that I have topped up with 500ml and hasn't made a difference. It's just I have a long journey coming up and don't want to get caught short ! Oil I used when I done the last change was valvoline 5w30 fully synthetic. Also I have had a look under at the drain plug and no sight of any leaks. However the oil cap had a fair bit of oil round it but I wouldn't say any more that expected.
BMW 325i M sport - Custom stainless exhaust ( 335i set up ) - Piano black interior trim - Gloss black kidney grills - Ferric grey 18" MV3 alloys -
07-16-2014, 11:47 AM | #2 |
Rep 22
I used to have similar problem.
During the oil change i put as much as recommended 6 quart. However, at the first drive after the oil change my oil level showed at low. I add a half of quart, and it never changed. i was driving for a couple of days thinking that the message will go away and it did not. I added the second half of quart and level did not change right away. Fortunately, after a few trips i guess computer retested on it's own and the oil level stabilized to normal. Take your car for a few short trips 15-20 miles. |
07-21-2014, 09:36 AM | #4 |
Long Time Admirer, First Time Owner
18018
Rep 9,378
Carry a bottle with you when you go. Any more, I ignore it until it tells me for 3 days straight that my oil is low.
08-01-2014, 01:24 AM | #7 |
Guest
Rep n/a
Drives:
Most of the time when these cars are using oil, you have a oil leak,
Check the valve cover gasket especially the exhaust side right above the exhaust manifold, you should be able to see oil if its leaking, followed by oil filter housing gasket, those are the most common. If it all looks clean move on to oil pan gasket/front and rear main seals. |
