Oil consumption
07-09-2014, 07:56 AM | #1 |
229
Rep 3,489
Drives: Montego Blue 335d
Oil consumption
Amigos I believe Im getting jipped by the dealer this is the second time my cars OIL lamp comes on, I have no engine leaks on my drive way, CANT see any leaks on the engine. What could it be either the DIESEL is burning oil or the dealer is stiffing me with not adding the correct amount? Please feel to respond to me ASAP. Gracias!!
P.D. I checked the oil stick and it showed low oil
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
07-09-2014, 08:09 AM | #2 |
73
Rep 697
I just did a 12,000 mile oil change interval.
I never had to add oil in between. Was down approximately 1/2 quart after 11,000 miles. Driven daily, hard sometimes, stop and go traffic, etc. My catch can also catches all the blow by oil, would expect maybe 1/2 a cup after 10,000 miles. If you are loosing oil, you are burning it past the pistons. Or, you are getting a lot of blow by routed back to your intake/engine. |
07-09-2014, 09:29 AM | #4 |
229
Rep 3,489
Planning to do so WHAT
Will chewck that 135i
07-09-2014, 09:33 AM | #5 |
158
Rep 866
Maybe PR doesn't have any biodiesel in the fuel. Bio will stick around and get into the oil making the level good.
I've had other diesels that required an extra quart at 5000 miles, and I would be the one to change the oil. PL |
07-09-2014, 09:55 AM | #6 |
229
Rep 3,489
I plan to start using AMSOIL got to renew my membership after some years w/o buying oil from them for my 02 MCS
07-09-2014, 11:51 AM | #8 |
158
Rep 866
I have always found Amsoil to be quite good. Sure wish they would get actual certifications for the applications they claim to satisfy, such as LL04.
07-09-2014, 11:51 AM | #9 |
33
Rep 655
I would suggest to use your dip stick to check the level after the oil change to see if they are adding the correct amount. Other than that keep in mind that our engines are designed to burn a little, it is the german thing, I never had oil light to come up yet but when I had benz that was a normal thing to add a little so often between oil changes. Harder to push more oil your engine will burn, that is something to keep in mind
07-09-2014, 12:06 PM | #10 | |
BMW Advanced Diesel, 2011 BMW 335d M sport...
87
Rep 783
BMW Advanced Diesel, 2011 335d M sport...
07-09-2014, 01:37 PM | #11 | |
Rep 73
07-09-2014, 01:43 PM | #12 |
229
Rep 3,489
I reckon tomorrow I will go to the AMSOIL dealer
07-09-2014, 01:51 PM | #13 |
229
Rep 3,489
Pierre just confirmed w my distributor their 5w30 meets LLO4 standards
07-09-2014, 01:56 PM | #14 |
157
Rep 716
07-09-2014, 02:00 PM | #15 |
229
Rep 3,489
07-09-2014, 02:21 PM | #16 | |
73
Rep 697
This is smaller than a BMS can. Diesels do get a lot of blow by. I haven't reached the 10k mark yet, but I am speculating 1/4-1/2 cup. Time will tell. Have 9k more to go! |
07-09-2014, 02:32 PM | #17 |
87
Rep 783
Why do you prefer Amsoil product, I prefer Liqui Moly brand for diesels...
07-09-2014, 03:23 PM | #18 |
41
Rep 800
I wanna say I've had 2 oil changes on the 335d and one on the x5d and no oil light came on. The x5 has an actual oil measurement on the computer and mine was at full right after the change.
Where's the oil light that's coming on? |
07-09-2014, 03:33 PM | #19 |
87
Rep 783
I wish my car had an oil level gauge, why does it not in the 335d?
07-09-2014, 03:56 PM | #20 | |
157
Rep 716
It is recommended for European gasoline or diesel vehicles requiring any of the following performance specifications: VW 504.00/507.00The Mobil 1 ESP 5W30 datasheet say: Mobil 1 ESP Formula 5W-30 has the following builder approvals: BMW Longlife 04The difference here is that Amsoil recommend their oil vs. BMW approving an oil. |
07-09-2014, 03:57 PM | #21 |
213
Rep 2,210
Mine has always required a half quart after the oil change when checked 10 minutes after shutdown. If the dealership is only giving you 8, then you're only burning a half quart over 13k miles, that's not bad.
Check your turbo oil feed lines if you're looking for a leak |
07-09-2014, 04:00 PM | #22 |
870
Rep 2,615
