07-08-2014, 10:41 PM | #1 |
58
Rep 151
Rear Fog Lights
The owners manual has a section on the rear fog lights but as usual the switch on the U.S. cars is non-functionable. I know there is mod for the E92, but has anyone figured out how to make it work for the F82
07-10-2014, 01:24 AM | #2 |
39
Rep 216
Wasn't there a plastic stopper in the back of the blank switch on the E92 and all you had to do was remove it to get the lights to work? Can you post a screenshot of the location the fog light switch is in the manual? I'll try to mess around with it to see if its the same deal as the E9X.
07-10-2014, 02:51 PM | #3 |
55
Rep 670
should be like the f10 ... replace light switch with euro part number and should work without coding
07-11-2014, 10:32 PM | #5 |
55
Rep 670
07-12-2014, 04:28 AM | #6 |
39
Rep 216
That's the mistake I made in my E92. I bought the Euro switch and later found out that all I had to do was remove some sort of stopper on the US switch for it to work. Wasted money on the Euro switch. I want to find out if it is the same thing with the F82 before I go ordering a Euro switch.
07-12-2014, 05:32 AM | #8 |
55
Rep 670
How did that work? Was the fogs on every time the headlights were on ? Confused as the us switch has no fog button ... You don't want to be one of those tools they drive around with rear fog on when it isn't needed do you.?
07-12-2014, 10:23 PM | #9 | |
58
Rep 151
I noticed that in the F82 M3. The button/switch for the read fogs wiggles a little when touched |
07-13-2014, 02:08 AM | #10 |
39
Rep 216
The US switch does have a fog button. It's just not labeled and it comes with 4 tabs that prevent you from pressing the button down. My area occasionally has dense fog so this mod would be useful.
07-13-2014, 10:50 AM | #11 |
M3AT LOVER
322
Rep 1,853
savaho, if you do this mod, would you take some pictures? thanks.
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
07-13-2014, 10:52 AM | #12 | |
55
Rep 670
I thought the mod would force rear fogs on all the time with headlights on from what was being described above. |
07-13-2014, 11:06 AM | #13 | |
76
Rep 521
2015 Alpine White ///M3 | Sakhir Orange/Black Extended Merino Leather | 6MT | Lighting Package | Harmon Kardon | H&R Sport Springs (F32) | iND Cosmetic Treatment | M Performance Spoiler | 19" HRE 301M Frozen Red| Mode Carbon Trophy R1 Diffuser
07-14-2014, 03:46 AM | #15 |
39
Rep 216
I had a hunch that other people with different models would also be interested in doing this mod and sure enough there was already a DIY for it in the F30 forum. Good news is this mod can be done. Bad news is you'll have to code it after modifying the button for it to work. Pics of the rear fogs on an F30 don't look good to me so I will pass on this mod.
Note: The OP in the thread below removed the whole switch assembly in order to remove the button but this is not necessary. You can remove the button by simply prying it out using the notch on the bottom of the button with something like a flathead screwdriver wrapped with a soft cloth. http://f30.bimmerpost.com/forums/sho...d.php?t=877278 |
07-14-2014, 08:58 AM | #16 | |
55
Rep 670
Seems like a very easy mod to the switch. Anyone who needs help with the coding ... send me an e-mail ... I do coding for forum members @ no charge locally & remotely. ************************* |
07-15-2014, 01:35 PM | #17 |
508
Rep 929
FWIW the euro part number should be 61319265229, There are many versions of this switch, but since the M4 has no front fog lights the top fog light button is not there, on the Euro version there is the addition of the rear fog light button located to the bottom of where the front button should be, the photo from the manual shows this switch in question, I suspect the US versions have no fog light buttons at all. So there you go.
07-23-2014, 10:05 PM | #18 |
1ST CLASS AWMSPORT
74
Rep 789
Drives: 13' 328 MSPORT
My friend just picked up new M3, headlight is same as mine, 13 msport...allbu do is shave the end tabs off and its PERFECT
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon: JB4,DP,H&R sports,rear diff,! |
08-13-2014, 12:55 PM | #20 |
Commander-In-Chief
2070
Rep 8,898
Drives: 2023 M2 Coupe, 2020 GLE 450
Rear fog coding
Saw this in another post today, now can't find it, so apologies for no credit:
"There are 5 different settings that you have to turn on in order for them (rear fogs) to work. F80/82 should be the same as the F30 and i know the US Spec models come with the Adaptive Brake lights which uses the same bulbs as the rear fogs. Here are the 5 settings you need to code: REM / 3063 / Mapping_Nebelschlussl_L_output /New Value = nsl_L REM / 3063 / Mapping_Nebelschlussl_L_function /New Value=nebelschlusslicht REM / 3063 / Mapping_Nebelschlussl_R_output /New Value = nsl_L REM / 3063 / Mapping_Nebelschlussl_R_function /New Value = nebelschlusslicht Fembody / 3060 / NSL_Verbaut / New Value= Verbaut You can also turn the Euro Spec adaptive brake lights on. The inside brake lights and the 3rd brake light in the window strobe when you hit the brakes real hard instead of just lighting up like the standard US spec lights do. Here is the code for that.. Fembody / 3060 / ESS_AKTIVIERBARER_AUSGANG / New Value =bremschlit_blinkend you can find a video on youtube if you type in Dynamic Brake Lights"
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
