E85 with JB4
07-08-2014, 10:08 PM | #1 |
136
Rep 1,192
Drives: 2011 335i MT
E85 with JB4
Found a Valero near my house that sells E85. Its a pain to get in and out of this gas station due to the location, but its very close so I just have go there during off-peak times.
I'm on JB4 map 5 and did an approx 60/40 mix of 93 octane/E85. Car pulls very nicely. Is there any "ideal" ratio of 93 to E85? Any other suggestions for running E85 with the JB4?
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
07-09-2014, 06:26 AM | #3 |
51
Rep 260
Do you have flex fuel wires? I think 30% is what you can run without the wires. I run 50% (8 gallons) on mine with the flex fuel wires. Be sure to "teach in" map 5. Do 3-5 pulls in 3rd gear. Start at 2500rpm and take it to redline. You will see boost climb each time you do it until you max out around 18psi.
11 335D - BPC stage 2.5
13 X5D - Family hauler 01 Cummins 3500 - 1100 torques |
07-09-2014, 09:56 AM | #4 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
20% max without FF wires. I run E40 also and I hit the full 18psi map 5 will provide. E30 is probably all we need, but I go a little higher in case I get some E85 with lower content. Even though it says E85 it is never actually E85. Many places are E7x.
07-09-2014, 11:43 PM | #5 |
136
Rep 1,192
I don't have flex fuel wires. What do those do and where can I get them?
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 Last edited by snaimpally; 07-09-2014 at 11:51 PM.. |
07-09-2014, 11:58 PM | #6 | |
93
Rep 716
Drives: 2015 YMB M3
They are used to bias the fuel pressure signal, tricking the DME into thinking its injecting less fuel than it actually is. 20% mix is fine without the wires though
2015 BMW M3 | DCT | Yas Marina Blue | Silverstone | Executive | Lightning | Driver Assistant | Carbon Ceramic Brakes Instagram: @benrivasplata |
07-10-2014, 12:03 AM | #7 |
93
Rep 716
Drives: 2015 YMB M3
Get them for $25 at burgertuning.com
07-10-2014, 08:28 AM | #8 |
136
Rep 1,192
07-10-2014, 09:12 PM | #9 |
28
Rep 583
Just put 6.5 gallons mixed with 93 to make a full tank. How long before I should "feel the effects"
Yes I have FF wires
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
07-10-2014, 09:28 PM | #10 |
The dude abides
50
Rep 265
07-10-2014, 10:39 PM | #11 |
28
Rep 583
Pretty sure he's just talking about adapting map 5 to your car once the E85 is established
07-11-2014, 12:54 AM | #12 |
13
Rep 292
Drives: 2013 BSM 335i Coupe M-Sport
just ordered my ff wires.. excitedd ! is there a significant diff in power from using 93gas, map 5 to now being able to add 40/50% e85 ?
07-11-2014, 08:18 AM | #13 |
245
Rep 1,595
Yes, difference is as great as going from stock to stage 1. I just got some bad E85 though and it is pulling timing. Time to figure out how to burn up this tank of gas fast...
07-11-2014, 08:44 AM | #14 | |
51
Rep 260
Damn that sucks. The E85 station near me is sketchy and I had a bad tank recently. There is a BP 15 min from my job, but it's completely out of my way logistically. I wish they would open more E85 stations in the south east.
