Clutch noise help :(
07-08-2014, 01:15 PM | #1 |
111
Rep 549
So my clutch started making shuddering noises everytime I pressed it, would do until about half way and then nothing. It disappeared after a while so left it and now it's back. Took it to my local garage and they said the flywheel has gone and I should replace the clutch. They estimate about £900, is this about right?
They did say we'll have to take it apart and make sure so is it possible that it could be anything else which could be less costly to sort out :/ All help and suggestion appreciated Last edited by GOWRIN; 07-09-2014 at 04:00 AM.. |
07-08-2014, 01:48 PM | #2 |
26
Rep 358
Clutch release bearing or DMF
Got the same on my car... 4 months now and it still hasn't knackered completely so you can drive for a bit if your strapped for cash just avoid holding clutch down for long periods, especially at lights leave it in neutral If it's the clutch release bearing then get a clutch kit but the majority of the cost is the labour so I doubt itl be a cheap fix |
07-08-2014, 02:02 PM | #3 |
Photographer
412
Rep 2,643
Yup, most likely clutch release bearing, you'll be doing the clutch too as it's a kit, so either way it will fix it.
Mines doing it, just cutting down on unnecessary trips, not feeding the clutch too much, no sitting clutch up in gear, planning gear changes to minimise clutch action. I'm doing flywheel and gearbox oil at the same time for peace of mind. Friend works at a garage so it's costing £600 all in. |
07-09-2014, 03:57 AM | #5 | ||
111
Rep 549
Once the car is rolling there isn't much noise, but more when in lower gears or driving slowly or a complete stand still.
Yes I did read your post and got worried about the costs and took it to the garage. That is a lot, I feel your pain! |
07-11-2014, 02:36 AM | #7 |
100
Rep 476
Mine was the DMF, it took a year of the noise to get really bad. When i took it off it was on it's last legs. You'll know when the noise is bad and needs doing. The faint noise when you half press the clutch is not that bad. Car did 100k and the clutch was still in good shape.
07-11-2014, 04:41 AM | #8 |
Photographer
412
Rep 2,643
The thing is you're paying for the labour to get the box out, you may as well get it all done if you can afford it.
It could be the flywheel but I'd want to say it's the release bearing personally. As said I'm changing it all, but my cars done 175k so it's not unexpected costs. |
07-11-2014, 04:57 AM | #9 | ||
111
Rep 549
There doesn't seem to be a simple way to upload a video but found something similar.
07-11-2014, 02:45 PM | #10 |
Photographer
412
Rep 2,643
Mine was the clutch release bearing starting to collapse and just the clutch being worn in general, contact patch was fine but had a lot of play in.
Flywheel was worn too but probably not the source of the noise. |
07-11-2014, 03:03 PM | #11 |
Wheelbarrow Edition
60
Rep 1,608
My 320d also does the same
Started feintly at around 73k miles Still going strong at 88k miles. Noise has increased slightly but not to the point of changing. I will be uprating it when i change as i like things to be fit and forget. Only uprated clutch i can find at the minute is the sachs sre. Not many make clutches for the e90 320d m47. I wondered if the older e46 shared the same clutch as the early m47 320d 163bhp engine |
07-11-2014, 03:57 PM | #14 |
Photographer
412
Rep 2,643
Mine started 3 weeks ago, and was loud enough by today for pedestrians to look at my car in traffic as I dip the clutch to put it in gear and pull away.
I genuinely don't think I could drive much more than the 1000 miles I have done since the sound started. |
07-11-2014, 04:05 PM | #16 |
283
Rep 2,796
Like the others have said really we do a fair few clutch/DMF they are sadly common on the 330d 320d and alike, the clutch kits come complete then you need a flywheel, LUK make the gen BM kit you can sometime hook up a good deal at Euros for example.
07-14-2014, 08:28 AM | #17 | ||
111
Rep 549
Yeah I found some LUK ones online for 450, clutch and flywheel which is the best price I've seen. I think I will see how long it will last before it gives up on me. It was either go on holiday or clutch... |
