Rough Warm Starts?
07-06-2014, 11:53 PM | #1 |
129
Rep 1,052
Rough Warm Starts?
Hey everyone...
I just had my valve cover (not gasket) officially known as the cylinder head cover, part # 11127552281 as listed on RealOEM replaced due to continued slight leaking after the valve cover gasket was replaced several months ago. (dealer found a hairline crack in the cover itself) I've noticed since this was replaced that on warm starts the car seems to be rough/struggling/hesitation at start. There's a noticeable shake to the car when I'm sitting in it that wasn't there before. Seems to smooth out and run fine after 15-20 seconds of running at idle and driving around town and on the highway has no sign of issue. Just looking thoughts on why this might be happening. I tried to shoot some video from inside and outside of the car but nothing is really picking up the rough/struggling/hesitation at start.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White |
07-11-2014, 12:29 PM | #2 |
129
Rep 1,052
Turned out to be coils 4 & 6 firing but at lower output than the rest of the coils. Not causing a code, but causing intermittent misfire and knock and rough idle.
All coils are getting replaced.
07-11-2014, 12:32 PM | #3 |
964
Rep 3,854
Drives: 330i, 135i
07-11-2014, 01:05 PM | #4 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
That's interesting. How would one diagnose a coil like that? Genuinely curious. Is there a tool one could use or does the cars DME save this info and you can pull it through dis/inpa?
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
07-11-2014, 01:16 PM | #5 | |
129
Rep 1,052
He then told me this morning that coils 4 & 6 were firing weaker than the rest and he's replacing all of them to prevent any need for a repeat visit (My CPO is up in 2-3 days anyway) and because I've talked about this issue with him several times in the past and he was unable to find anything stored in the DME. Im just thankful he's awesome and got to the bottom of it. It's my impression this took him a good amount of time.
07-11-2014, 01:17 PM | #6 |
129
Rep 1,052
You are very welcome. Anything that helps the community.
07-11-2014, 01:21 PM | #7 | |
35
Rep 1,652
Excellent, thanks for the follow up.
07-11-2014, 01:46 PM | #8 |
Accepting Donations
Rep 333
Drives: Montego Blue E92
Any idea of what said diagnostic equipment/raw data is?
I remember seeing a while back some one testing their coils with a voltmeter but then some one else said that wasn't completely accurate...
2009 Montego Blue E92 Sold
07-11-2014, 01:47 PM | #9 |
129
Rep 1,052
Nope.
07-11-2014, 02:19 PM | #10 |
964
Rep 3,854
Drives: 330i, 135i
I would like to test mine too. I am still running on originals so they are about 9 yrs old. I changed the spark plugs myself last year but not the coils as they looked goods still.
I will look online but if somebody has a procedure how to test these let me know... |
07-11-2014, 03:09 PM | #11 | |
129
Rep 1,052
07-11-2014, 05:49 PM | #12 | ||
129
Rep 1,052
Coming from a computer service background in my teens/twenties, I agree with him. I knew a lot of the older hands on troubleshooting techniques. A lot of my younger employees only understood how to run a diagnostic and read the results. Glad not to be in that industry any longer. Anyhow, he said he used a kV Adapter between the coil and the plug, Oscilloscope and his eyes. Aparently a lot can be learned by looking at primary and secondary spark firing lines, comparing them to the data gleaned from the kV Adapter and Oscilloscope. You just really have to know what you're doing. In my case, it became clear to him that these two coils were not providing the necessary kick. I guess this kind of thing is why he's a BMW Senior Master Technician. I'm just glad to know him.
