Something is wrong... Please help!!!
07-04-2014, 01:30 AM | #1 |
167
Rep 1,415
For a while now. My car has been acting up. Cold or hot, sometimes when i start the car the rpm will drop super low almost die then come to life. Every so ofter it will just die so i turn off car and do it again. When its running its fine. I watched my lpfp and hpfp values and they are within limits. I also just had my valves cleaned by clem. Does anyone have any ideas? Do we have a icv? Could a boost leak cause this? Any other sensors i should have checked out? Im at 90k so im sure something has gone bad. Please let me know your ideas. Dont wanna be stuck somewhere.
2007 335XI SEDAN // JB4 G5 // BMS METH KIT // VRSF DOWNPIPES // AFE DCI // ER CP W/ TIAL BOV // MMP SILICONE INLETS // XHP STAGE 3 AT FLASH // TREBILA BEF // BMS OCC // VRSF EXHAUST // FUEL-IT STAGE 2 LPFP // VRSF FMIC // PRECISION RACEWORKS IGNITION SYSTEM // CATUNED COILOVERS // CIC AND COMBOX RETROFIT //
07-04-2014, 01:34 AM | #2 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Could be a sensor or injector? You're not getting any codes? Just throwing things out, pure conjecture.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
07-04-2014, 01:52 AM | #3 |
167
Rep 1,415
No codes man. Shit is pissing me off. If this thing dies on me one more time and i get stranded im leaving it there.
I just reset adaptions with jb4. Probably not the best idea. Rpms started bouncing. Turned it off. Restarted. Its not bouncing anymore but it still almost died. Which sensors could cause this? Do we have a idle control valve? Injectors got replaced under warranty last year. (Not sure which ones or all) |
07-04-2014, 01:56 AM | #4 | |
35
Rep 1,652
an o2 sensor going out can cause idle issues. Idk much about diagnosing though. Keep us updated please. Hopefully someone with experience can chime in.
07-04-2014, 02:13 AM | #5 |
167
Rep 1,415
Ok. Ill check o2 sensors. Sucks they are such a pain. Is there a way to diagnose them? I would think it would throw a code if they were failing.
As a update: when i got my valves cleaned. They noticed the o ring from my cp was missing. I hope it didnt get sucked into the engine...... Im going to replace it tomorrow. Ill update again. |
07-04-2014, 09:47 AM | #6 | |
42
Rep 213
11 Space Grey, M-DCT Base M3
