Jack Pad installation
07-03-2014, 09:06 PM | #1 |
26
Rep 122
This sounds really stupid and i hate to ask, but is there a trick to installing new jack pads or points on our cars. i purchased the ones in the link below for my 07 e92, but they dont just pop in there like i saw in the youtube video. Just wanna check before i force them too hard.
http://www.ecstuning.com/BMW-E92-335...Pad/ES1599379/ Thanks, Jeremy |
07-03-2014, 09:10 PM | #2 |
Guest
Rep n/a
Drives:
You need to slide a butter knife like tool (but shorter so it fits in the small space you have to work with) at the ends and press in the clips while pulling down, it took me hours to remove 1, then about 10 seconds to remove the other 3.
A small flathead screwdriver should work too You don't need any brute force whatsoever, its easy once you have the technique down. So slide the flathead in press firmly to push the clip release, then on that corner pull down and it should swing out and off. |
07-04-2014, 12:23 AM | #3 | |
129
Rep 1,052
I haven't done one but I assume it would be the reverse.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White |
07-04-2014, 01:32 AM | #4 |
VIP
52
Rep 747
Drives: AW E92 335is
So easy to install them. All you gotta do is --------------- then make sure the pads ----------- once you do that. You're done.
AW 2011 E92 335is | JB4 G5 | AFE Dual Cone | ER CP with HKS BOV | VRSF DP's | 7' VRSF FMIC | Wedge E85 Flash
07-04-2014, 02:23 AM | #5 |
77
Rep 980
Drives: '08 BSM 335i e92
Can't you just align the pad with the location that it goes into on the car, then start jacking up the car with a floor jack, and the weight of the car should compress the pad into the location? That's what I would do
'08 BSM E92 335i 6MT/MHD stg 2+/VRSF 7" FMIC/VRSF CP/HKS BOV/VRSF catless DPs/BMS DCI/muffler delete/BC Extreme lows/OEM style 167s/BMS high side OCC/Mishimoto low side OCC/etc
07-04-2014, 05:07 AM | #6 |
12
Rep 335
But first make sure the clips are in the slots. Otherwise the jack pad clips will brake.
07-04-2014, 04:02 PM | #10 |
77
Rep 980
Hence why I said align the pad with the location...... in other words.... put the clips in the slots.
