FS: BMS Meth Kit + FSB
07-03-2014, 12:41 PM | #1 |
Rep 254
I have for sale an upgraded BMS meth trunk kit.
It has upgraded high-end brass fittings and a professionally sealed 1 gallon tank so that there are absolutely no leaks. Been using it for almost 2 years and I never had an issue with flow or leaks. Includes the updated solenoid and fittings. The pump was upgraded to Snow Performance because coolingmist is garbage (no offense). Located in the GTA. $400 obo Last edited by 11SEC; 07-18-2014 at 08:32 AM.. |
07-16-2014, 04:52 PM | #4 |
583
Rep 2,233
Drives: '12 M3
Gets you high as a kit and trip balls. Breaking Bad will have all the answers for you!
...just kidding. It allows you to make more power by injecting methanol into the induction side of things. |
07-18-2014, 08:32 AM | #7 |
Rep 254
GTA
Quite a bit. Probably around 30-40whp at least. It's not even the power increase thats the biggest benefit, its the constant/consistent power. In the summer your car will heatsoak even with an intercooler. Meth lowers your IAT drastically and you will always have consistent power no matter the weather. Without meth you're boosting around 14-15psi and with meth you can go between 17-19psi on stock turbos. |
