Boost Leak?
07-02-2014, 03:08 PM | #1 |
Rep 45
Boost Leak?
Hey guys I was wondering if anyone had any experience with a boost leak? I have a N55 335xi with JB4, BMS chargepipe, VRSF catless Downpipe, and BMW Performance Exhaust. I have my JB4 set to hijack my fuel gauge for boost when I'm over half throttle. I read the half way is 10 psi and 3 quarters is 15psi please correct me if I'm wrong, Anyways Ive noticed that when I pin it, it will bounce up to 14 psi (running map 2) then bounce down to around 4 psi and stay there or keep bouncing back and forth. I will be making a log of this tonight. I'm just wondering if anyone has had experience with this.
07-02-2014, 07:33 PM | #2 |
Rep 45
So I'm dumb and had a girl moment but I was logging timing on my fuel gauge cause I had the wrong setting on my JB4, however I still found some issues while I was logging. The first concern I have is when I am under WOT my AFR's stay around 14.7 which I always thought that under WOT I should see around 12, so I'm worried that I might be running to lean when I'm under WOT. Second I'm still not seeing 14 which is what the map 2 is supposed to run. I am kind of confused on boost because I can see what its commanding but It never seems to meet it. I dont think its a boost leak because the wastegate duty cycle is sitting pretty high which doesn't make sense because if it can't make its boost why would it open the wastegate?
07-02-2014, 07:36 PM | #3 | |
215
Rep 1,818
07-02-2014, 07:58 PM | #4 |
Rep 45
