BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Fuel injector cleaner help.
      07-02-2014, 05:17 AM   #1
BashShah
296
Drives: 2012 335i Sedan
Car is a 2007 335i Sedan.
Build sept 06, if this matters.
I am starting to have a slight ruff idle without codes.
It is clearly missing every 10-15 sec, at start up till it heats up to normal temp.
Walnut blast done less than 20k ago.
Heard and read about techron fuel system cleaner.
Bought the 6 pack from Costco.
Havn't used it yet, as car gas is full.
Bottle says to ad to 12 gal.
My question is, did I buy the wrong stuff? (Edit Pictures added for what I bought)
What is the techron fuel system cleaner?
And what is techron concentrate fuel system cleaner.
Heard and read that this may fix my ever so slight issue.
But which one?
Thanks in advance.
DN
      07-02-2014, 05:31 AM   #2
Delta0311
7478
Drives: 2011 BMW 335xi E92 2016 228xi
I take it you got the one that treats up to 12 gallons. We got like a 16 gallon (might be a bit more) fuel tank, so go for the 20 gallon bottle. All you do is dump the bottle in before you fill up.
      07-02-2014, 06:14 AM   #3
F36Vader
F36Vader's Avatar
238
Drives: 435i Gran Coupe
Chevron techron isn't ready available in my city (Toronto) so I opted for "Gumout Fuel Injector Cleaner"
I can confirm that it REALLY helped with the rough idles. I was actually getting vibrations.. Also Walnut blast has been done 7,XXX ago.
Once you dump the cleaner in I suggest driving the car in DS mode or just let it hit the higher revs to really clean those injectors.
2015 435i xDrive Gran Coupe - Black Sapphire, M Sport, MPPK, MPE
RIP; 2015 C63 AMG Coupe - Obsidian Black, 507 Edition
RIP; 2009 335i Sedan - Titanium Silver, Sport pkg, Premium pkg, FBO
      07-02-2014, 07:41 AM   #4
335NJ
533
Drives: 2008 335i 6MT E90
I just ran a bottle of the Techron stuff through my car, and it seems to have smoothed the idle out A LITTLE bit. My assumption is you have to continuously run this stuff a few fill ups for the maximum effect. Or, my valves are carbon caked and need cleaning which no additive will help with.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
      07-02-2014, 07:53 AM   #5
Sandman614
Accepting Donations
Sandman614's Avatar
Drives: Montego Blue E92
2009 E92 335xi  [0.00]
Aren't you supposed to wait till the tank is near empty, put in the techron, then fill up
2009 Montego Blue E92 Sold
      07-02-2014, 08:04 AM   #6
Delta0311
7478
Yup that's the way I always done it.
      07-02-2014, 09:21 AM   #7
David1
David1's Avatar
No_Country
814
Drives: 09 E92 09 X5
You have an injector or two starting to wear out.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
      07-02-2014, 09:25 AM   #8
Louiscipher
Drives: 2006 Monaco Blue
^^^What they said is correct, I have a bottle of Liquid Molly fuel cleaner I will try in mine when I take a trip to Savannah this weekend.
http://www.liqui-moly.de/liquimoly/p...cument&land=GB
      07-02-2014, 09:36 AM   #9
Longdoggy
Master Bates
Longdoggy's Avatar
80
Drives: 2020 BMW M340 xDrive
Chevron techron... Good stuff.
If you have rough idle, try a 20g bottle before every other fill up for about 2-3 cycles and see if it helps.
If not you may need some engine work done. But continue techron treatment like every 2k-6k miles to keep things working well.
Read about the stuff, some experiments were done with some fantastic results.
If you can't buy local check Amazon. $6 bucks and change.
Highly recommend.
CURRENT: 2020 G20 M340 xDrive — Carbahn Tune
RETIRED: 2011 E90 335i xDrive — Cobb AP3, PE Exhaust, Alpina TCU Flash, VRSF Charge Pipe
2017 Estoril Blue X1 M Sport — JB4
      07-02-2014, 10:17 AM   #10
BashShah
296
So I bought from Costco USA. $19 for 6 of them.
Toronto guy, call your local Costco, they have it here in Costco in BC. I was just state side on Canada day do just bought it there.
Also, what exactly is the point of putting this stuff in before fill up or after, it will still mix right?
DN
      07-02-2014, 10:43 AM   #11
David1
David1's Avatar
No_Country
814
Once a DI injector has an issue it's done. Also, many times it's the electronics (the piezo section) that is bad and has nothing to do with the injector being clean or dirty.
      07-02-2014, 03:49 PM   #12
BashShah
296
David can you clarify this please?
I would like too look this up.
DN
      07-02-2014, 03:54 PM   #13
Hotsauce335
Drives: Hunting for 335
My thought too, either wearing out or starting to leak. Can you isolate what cylinder? If so, swap the injectors & see if the problem migrates?
      07-02-2014, 04:16 PM   #14
DJtoad
58
Drives: 2010 535i M Sport
DN
Did you get Chevron Technron concentrate or Chevron Pro-Gard with Technron? I think Costco sells the latter and they're not the same. The cheaper Pro-Gard product is to help keep the fuel system clean, not actually clean deposits. It has a much lower concentration of Techron and is therefore much cheaper in price.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus
      07-02-2014, 05:09 PM   #15
GB-335xiCoupe
Libertarian
GB-335xiCoupe's Avatar
132
Drives: 29k mi per year.
I seem to remember reading somewhere, that you have to do some coding if you swap your injectors. Not sure, I've not researched it...
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi
Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k
Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k
      07-02-2014, 06:18 PM   #16
Sandman614
Accepting Donations
Sandman614's Avatar
you have to code the injector flow calibration to the new cylinder using INPA
      07-03-2014, 07:09 AM   #17
Hotsauce335
If the OP considers the injector swap & program route, here is a link to some helpful information http://www.n54tech.com/forums/showthread.php?t=15140
      07-03-2014, 11:18 AM   #18
BashShah
296
OP Here, I got this: Techron Fuel Injector Cleaner
16 FL. OZ. (472 mL)
see Pictures in edited first Post.
      07-12-2014, 08:59 AM   #19
Chriztofor
Chriztofor's Avatar
103
Drives: '06 325i and '13 X5
By the way, guess what brand the BMW dealership is using.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
      07-12-2014, 02:43 PM   #20
BashShah
296
Thanks Chris.... Guess I am returning the stuff from Costco.
DN
      07-12-2014, 03:13 PM   #21
kaede
81
Drives: 2008 E90 M3
DN
Yes go return that. That is not the same as the Techron Concentrate Plus - Fuel System Cleaner. Good Luck!!
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold)
01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold)
08' E90 M3 6MT - DD
13' W212 E63 AMG Wagon
      07-12-2014, 03:46 PM   #22
Tom Droze
413
Drives: 2012 BMW 328i (e92)
Make certain you do not confuse Chevron Pro-Gard with Chevron Techron. The Techron is the good stuff.
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
