Oil Change using Oil Extractor
07-01-2014, 03:51 PM | #1 |
31
Rep 402
Drives: 2015 550i xDrive
any have any experience with this? Thinking about buying this to make my first oil change easy. Oil Extractor - Inserts Into Dip Stick Tube
http://www.bavauto.com/fland.asp?part=PE30899 |
07-01-2014, 04:26 PM | #2 |
441
Rep 1,347
We used to use this in the shop when drain plugs were impossible to remove without damaging the pan. It was pretty cool. NOt a fan honestly bc if there is shavings at the bottom of the pan, it doesnt remove it as well as draining the oil from the pan. Gravity is your best friend in this case.
I used it once then took the plug off and flushed oil through. More dirt and gunk came through the pan than the vacuum. |
07-01-2014, 07:18 PM | #5 |
Rep 132
The extractors are very nice, I own the MV7201. But on these BMW engines, there is no where to insert one. I use mine to suck the oil out of the filter housing, but it is literally super simple to pull the drain plug on our cars.
2011 335i Coupe M Sport: Alpine White
07-01-2014, 07:50 PM | #6 |
Curmudgeon and Pedant
690
Rep 3,489
07-01-2014, 09:01 PM | #7 | |
31
Rep 402
07-01-2014, 09:14 PM | #9 |
31
Rep 402
damn it, i thought it could be done from where the dipstick is located. thanks for ur help
07-01-2014, 10:10 PM | #10 |
690
Rep 3,489
07-02-2014, 08:27 AM | #11 |
Rep 132
It works great on on my Honda for oil, or my grandparents Lincoln transmission fluid, but with there not being a dipstick on your BMW, it is impossible. Now if you had a Merc....
07-02-2014, 12:09 PM | #13 |
31
Rep 402
thanks for the clarification, just bought this car a little over a month ago so I'm still learning. Sorry for the ignorance fellas lol
07-02-2014, 09:09 PM | #15 |
17309
Rep 18,733
An oil extractor is a useful tool. You can use it to change the diff oil, pull brake fluid out of the reservoir, and pull the excess oil from the OFH. And it's great for lawn mowers too!
