Dealers!
06-30-2014, 08:34 PM | #1 |
1436
Rep 2,526
Drives: 2011 328i Wagon
Dealers!
Had my car into the local dealer today to do a very simple warranty task - the passenger side door seal had worn through and split. Simple enough job, yet they did not manage to get it back together correctly. Seal not even remotely seated correctly, tucked under the wrong bits, and generally a complete and utter mess. I cannot imagine how they thought the job they did was acceptable! All they had to do was look at the other side of the car to see how it is supposed to be. And a grubby handprint on the windshield trim to boot.
And the really annoying thing is that this is the SECOND time - they did the driver's side just as badly a couple years ago. In both cases, took me all of 5 minutes to sort it out, but why could they not take the 5 minutes?! They had better hope I don't get a survey on this one! I complained last time that it wasn't done correctly, but it's easier for me to just fix it myself than to go over there.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
06-30-2014, 09:39 PM | #2 |
129
Rep 1,052
Did you look at it before you left? Always check any cosmetic fixes when you pick it up to make sure it's done to your satisfaction. If not make them correct it on the spot.
You should email the GM and Service Manager and let them know about the improper job. Especially on basic stuff like this. |
06-30-2014, 09:43 PM | #3 |
Libertarian
132
Rep 1,577
Yet another case of DIY rulez!
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
07-01-2014, 06:06 AM | #4 |
1436
Rep 2,526
Exactly why I would never pay to have something like this done! I would have preferred that they just give me the warranty part and I put it on myself.
