Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      06-30-2014, 03:41 PM   #1
Sean@PSI
Sean@PSI's Avatar
2133
Drives: 2021 IOMG M3 Sedan
..::PSI::.. F8x M3/M4 Painted Side Marker DIY
Painted to match the front F8x BMW Performance front grilles, the painted side markers complete the removal of the factory chrome trim from the F8x M3/M4 chassis.
Tools we used:
Painter's tape
Nylon or plastic pry tool
Microfiber
Gloves
STEPS:
First, we recommend lightly dusting the area with a clean microfiber. Then apply painters tape around the complete side marker, making sure to get as close as possible to all edges. Be sure to completely surround any painted surface which you will be close to with the pry tool. This is a necessary step to ensure zero damage occurs to the fenders during the removal process.
Once the tape has been placed on the fender, we found it easier to separate the two parts that make up the marker and remove them individually rather than together as one unit. Using the pry tool, we carefully separated the chrome front from its black base.
Carefully free the front half of the marker from its base (held in by a few push clips), then reach into the fender from the wheel well and push on the final two clips to free it completely from the fenders vent.
Next, remove the black base from the fender by pushing on the visible clips holding it in place and pulling it off the car.
Once the base is removed, remove the tape and clean the fender to prepare it for the new marker to be installed.
Installation of the new marker can be done without separating the unit. Slide the front edge of the marker into the fender's vent and align the clips on the back with their respective holes on the fender.
After they are aligned, a light push is all that is needed to clip the new marker into place.
Using a microfiber, we cleaned off any smudges on the marker from handling it during installation to complete the install.
      06-30-2014, 04:34 PM   #2
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
24981
Drives: '22 Chalk Gray Porsche C2S
Nice. They DIY's are going to be extremely helpful. Where can we buy a similar prying tool?
      06-30-2014, 05:05 PM   #3
Sean@PSI
Sean@PSI's Avatar
2133
Amazon is best. It is important to use the correct painter's or automotive tape also.
http://www.amazon.com/Panel-Window-M...ylon+pry+tools
      08-01-2014, 01:18 AM   #4
M3.2.M4
///MD
33
Drives: 2017 MW ZCP F80. 2016 SG F15
[QUOTE=Sean@PSI;16214329]..::PSI::.. F8x M3/M4 Painted Side Marker DIY
I see no cables so I assume that there are no lights on the side gill??
      08-01-2014, 09:24 AM   #5
Bluehinder
12
Drives: BMW M5
Not any better than stock.
2018 GT350
2019 Ford Raptor
2021 Porsche GT4
2024 M4 Comp Convert
      08-01-2014, 10:16 AM   #6
Sean@PSI
Sean@PSI's Avatar
2133
There are no lights in the side marker at all.
      08-01-2014, 10:34 AM   #7
Zeroblade
Explodes on impact
Zeroblade's Avatar
209
Drives: 2006 Mazda3
I'm a little bummed out about this. I do think having the turn signal in this area makes more sense than on the mirrors.
Yea... yea I got an M(azda)3.... <.<
*work in progress*
      08-01-2014, 10:42 AM   #8
Sean@PSI
Sean@PSI's Avatar
2133
Definitely a change up from the E92. I like the fact that the mirror light is hidden somewhat, but ya I agree.
      08-29-2014, 12:34 AM   #9
hyperspeed
hyperspeed's Avatar
233
Drives: 2018 R8, MYP, GLE
I'm having trouble popping off the chrome trim from the black base. Do you have additional tips on how to get to the clips separating the two pieces?
2018 F80 M3 AW / SO
      08-29-2014, 01:20 AM   #10
Sean@PSI
Sean@PSI's Avatar
2133
Use a 90* pick tool, and wedge it between the chrome and the black. Make sure to properly secure tape around all of the painted surfaces (as we show) - it is not easy, but this method is the best we have found to not damage the vehicle.
      08-29-2014, 09:05 AM   #11
phantome46
phantome46's Avatar
112
Drives: 2015 M4 Convertible - Sakhir
Did you paint a standard set of gills or purchase factory black ones?
      08-29-2014, 09:29 AM   #12
Sean@PSI
Sean@PSI's Avatar
2133
These are originals - painted gloss black (from iND), the OEMs were not available in late JUNE.
      01-17-2015, 12:38 AM   #13
Powaup
Powaup's Avatar
1253
Drives: 2021 Supra 3.0 (Past: 2015 M23
2015 BMW M4  [10.00]
Broke one of the chrome side markers pulling it at the end... must be just me I also broke one the clips on the chrome kidney grille surround when doing that diy. Good call on the painters tape I would not do this install without it for anyone wondering
Check out my YouTube Channel Powaup
Instagram: @ Powaup
      01-17-2015, 05:59 PM   #14
Longbow64
_______
Longbow64's Avatar
169
Drives: 15 M3, 13 X3 35i MSport
If you can't get the pieces off of the vertical vent, just remove the vertical vent. There's two tabs along the edge closest to the sidemarker. One above and one below a little more than half the distance from the sidemarker.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat
      01-18-2015, 08:45 PM   #15
Sean@PSI
Sean@PSI's Avatar
2133
+1 , this always makes it easier as well. Depending on the car, the side markers vary in difficulty and the painters tape is a must.
      03-25-2015, 09:54 PM   #16
gtrsam
222
Drives: 2015 m3
saw u broke your side gill on a thread. which side is not broken? and would you sell it?
      03-25-2015, 10:09 PM   #17
Rain49king
104
Drives: 2015 M4
My car just had grills replaced. I will probably be throwing my stock chrome set on eBay. IDK what they are worth would probably list for $100 no reserve.
      05-13-2015, 10:35 AM   #18
2HIGH~PSI
2HIGH~PSI's Avatar
164
Drives: '94 Supra TT 6MT, '15 MW M4
has anyone removed the black fender grill? How does this come out?
      05-14-2015, 04:26 PM   #19
2HIGH~PSI
2HIGH~PSI's Avatar
164
^^ To further answer my own question as I did it yesterday and was quite simple.
There are only two clips on the back side of the fender black grill. One at top and one at bottom, After masking the area, you can just use the pry tool to pop the two back clips, then slightly pull straight back, not out away from the car as there are little nibs holding the front in place.
I did the side vents yesterday and I broke both chrome pieces trying to get them out as they were super tight against the black fender grill and wouldnt clip out, even reaching in the fender with my hand.
      05-14-2015, 04:29 PM   #20
Sean@PSI
Sean@PSI's Avatar
2133
The chrome pieces are super tight but with the proper tools they will come out without damage, it is not easy though.
      05-15-2015, 01:38 AM   #21
cmkde
36
Drives: Alpine White 15' M4
Just finished mine and ended up bending the original off and breaking it. Luckily they come off with ease this way but ideally I'd like to not have broke the originals. The tips above were all super helpful, wasn't expecting this to be more difficult than the front grilles, but worth the effort.
      05-15-2015, 11:01 AM   #22
2HIGH~PSI
2HIGH~PSI's Avatar
164
I just didnt care haha. If I ever want to revert back to stock (likely never) I can just purchase the stock ones again. Probably less than $50.
Tags
f80 m3, f82 m4, f8x side marker diy, new m4 diy, painted side marker
f80post
