2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes H & R Springs and Spacers Installed
      06-29-2014, 10:53 PM   #1
abirmaher
abirmaher's Avatar
839
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
  [0.00]
2018 BMW M2  [10.00]
Hi Guys,
Finally had my H & R sports springs installed today as well as some ECS Tuning spacers (12.5 mm front and 15 mm rear).
Overall i am very happy with how they came out. The ride feels about the same if not a tad tighter and I have had no issues with rubbing and from what I can tell I shouldn't have any issues, theres clearance.
Here are some before and after shots through the process.
I do want to say the spacers were a very tight fit not that thats an issue for now but getting them off in the future might be tough. Only real issue we faced was that the rear spacers (15mm) was that the spacers would not fit flush against the rotors because of the dust caps. So what we ended up doing was removing the dust caps and actually putting them on the spacer itself before putting the spacer on the wheel. We also put a dot of crazy glue on the cap so it would not spin in the spacer. And then we were able to put the wheel and spacer on no problem. These are pictures of that process:
One other consideration that I did not think about is that after having the suspension and all done you will need an alignment which I will hopefully find the time to do tomorrow.
Lastly a huge shoutout to the guys over at WTF Motorsports in Orlando! If your thinking about modding your BMW in Central Florida these guys are progressional, very helpful and do a great job. Feel free to PM me for contact info!
Before and After:
Other Pics:
Also if anyone is interested I have a thread tracking all my modifications on the car which you can feel free to check out here:
http://www.2addicts.com/forums/showthread.php?t=998066
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      06-29-2014, 11:09 PM   #2
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
looks really nice.... both the drop and the spacers...
hope you can add some pictures once the springs settle
BTW how do you take the dust cap off ?
      06-29-2014, 11:16 PM   #3
abirmaher
abirmaher's Avatar
839
  [0.00]
2018 BMW M2  [10.00]
I will and more impressions if my views change as well. And for the dust cap they used a flat head screw driver and just pried it off. Its just snapped in there. But to put it on the spacer it dosent sit super tight which is why we decided to put just a drop of super glue to keep it in place.
Follow my builds:
      06-30-2014, 09:39 AM   #4
zkeeper
zkeeper's Avatar
208
Drives: 2017 M2 & 08 Z4 si
You used the ECS... and am wondering if the Burger set allows for better dust cap fitment? Curious on this one.
Tech reminder to all: when wheels are off, clean even new hubs with wire brush, wipe clean and apply a small layer of anti-seize around outside of hub. New wheels and hubs start the differing metals & rusting process, and above will make it very easy for later removal.
      06-30-2014, 09:53 AM   #5
abirmaher
abirmaher's Avatar
839
  [0.00]
2018 BMW M2  [10.00]
If you find out about the buyer fitment let me know for sure, very curious as well. And yup we did that as well!
Follow my builds:
      07-06-2014, 07:21 PM   #6
HX_Guy
119
Drives: 2014 BMW M235i
Were the wheel spacers specific to the M235i or did they used ones made for another BMW?
Reason I ask is because I don't see any wheel spacers for the M235i on ECS's website and also H&R shows different part numbers and for the M235i and the E90 for example. Thee M235i has a center bore of 72.5mm while the E90 has 72.5mm and that could explain why the fitment was so tight.
      07-06-2014, 11:37 PM   #7
abirmaher
abirmaher's Avatar
839
  [0.00]
2018 BMW M2  [10.00]
Im not 100 percent sure to be honest as the parts were ordered for me.
Follow my builds:
      01-26-2015, 10:09 PM   #8
hoppy6698
hoppy6698's Avatar
127
Drives: M235i, Estoril Blue on Black
With Burger spacers, I can say they do not allow better cap reinstall of the dust cap. I ended up removing all the dust caps for installs. I might have been able to fiddle it on if I had put the cap on before putting it on the hub, but I wasn't too bothered and one wheel had massive rust on it when I took off the cap in the first place. At that point, I figured the caps weren't of that much use :P
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
      01-26-2015, 10:16 PM   #9
pikcachu
pikcachu's Avatar
1399
the cap won't fit in between the spacer and the hub...
I cut the cup and silicon glued it to the spacer
http://www.2addicts.com/forums/showp...6&postcount=46
http://www.2addicts.com/forums/showp...3&postcount=47
      01-27-2015, 01:28 PM   #10
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Nice write up. Car looks good!
      01-27-2015, 01:54 PM   #11
abirmaher
abirmaher's Avatar
839
  [0.00]
2018 BMW M2  [10.00]
Thanks... I'll be ordering a set of VMRs in the very near future too :-p
Follow my builds:
      01-28-2015, 12:36 PM   #12
Liquidpaper
Liquidpaper's Avatar
451
Drives: '15 M235i
2015 BMW M235i  [0.00]
Originally Posted by abirmaher View Post
Hi Guys,
Is there any change in body control (body roll)? Or does it feel pretty much like stock, but lowered?
      01-28-2015, 12:41 PM   #13
abirmaher
abirmaher's Avatar
839
  [0.00]
2018 BMW M2  [10.00]
Hi Guys,
Very much the same as stock I would say. That being said I only had it stock for 1200 miles and being at almost 12000 now I don't really have the best recollection of stock.
Follow my builds:
      01-28-2015, 01:03 PM   #14
mvallido
mvallido's Avatar
Philippines
70
Drives: M235i Estoril Blue
Looking good!
2014 M235i {Dinan P1 Power Package}
2015 F30 320i
2006 E90
2004 C240
97 E39 VF5 Supercharged
      02-17-2015, 12:40 PM   #15
scott@bmwhn
133
Drives: Msport X3
did you encounter any issues with your headlights being aimed to low after the H&Rs were installed?
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      02-17-2015, 12:41 PM   #16
abirmaher
abirmaher's Avatar
839
  [0.00]
2018 BMW M2  [10.00]
Funny enough I have been thinking about this in the past few days because they do seem to be a bit low but really havnt bothered me too much in the last 12000 miles. But I know it's a very easy fix so I may have it done next time I'm in for service.
Follow my builds:
      02-17-2015, 07:07 PM   #17
escobar929
escobar929's Avatar
154
Drives: M2 CS
2020 M2 CS  [10.00]
2020 M240i  [0.00]
Are they too low or not leveling out?
I had a similar problem with my 1 series after installing KW coilovers and it turned out we busted the sensor while removing the front strut
      06-29-2015, 09:41 PM   #18
YYZF22N55
YYZF22N55's Avatar
23
Drives: 2014 M235i
Is there any rubbing at the back?
Did you have to adjust your rear camber at all?
      06-29-2015, 10:49 PM   #19
abirmaher
abirmaher's Avatar
839
  [0.00]
2018 BMW M2  [10.00]
Only when I have a car full of med to large adults. But if I had stock wheels I'd be fine. It's because I'm running wider VMR wheels.
Follow my builds:
      06-29-2015, 11:51 PM   #20
YYZF22N55
YYZF22N55's Avatar
23
Drives: 2014 M235i
And front is no problem with stock wheels?
      06-29-2015, 11:52 PM   #21
abirmaher
abirmaher's Avatar
839
  [0.00]
2018 BMW M2  [10.00]
Neither front nor read. I ran then with front and rear spacers for a while with no running at all. So yeah you're fine.
Follow my builds:
      06-29-2015, 11:59 PM   #22
YYZF22N55
YYZF22N55's Avatar
23
Drives: 2014 M235i
Tried on 15mm in the rear today and shop seems to think the side will rub if i hit a bump. They said it wasn't safe and need a bit of neg camber in the rear.
I just don't to rip out my bumper if I hit a deep pot hole.
2addicts
