Weird overheat issue - anyone seen this?
06-29-2014, 09:58 PM | #1 |
863
Rep 5,448
Car is a 2008 garage queen, 18k miles owned since new, coolant changed last year.
No issues recently, nothing has been touched on the car in a year. Went for a ride today, 78 degrees on the highway, 5 miles from home, get the overheat light, yellow then red right away. Oil temp is 180, coolant is at 253!!! Pulled over shut it off for a bit, got down to 210 degrees figured I would get off the highway as exit was close, started it up, got on the road and coolant temp drops to 180 almost instantly, then slowly heats up to 200 and just sits there for the drive home, no issues. Checked codes with the BT cable, no codes, weird! Ran the pump tests from BT comes on and runs fine, sounds a little noisy to me, but never listed to it before with car off. Also thought it was odd the rad fan was never load like most people experience, at 250 for coolant temp, I would think the cooling fan would be on high. It is almost like the car wasn't that hot and just reading high. My commute is short so will see what it does tomorrow I guess, was totally expecting a code and to be ordering a pump, but now not sure?
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
06-29-2014, 10:05 PM | #2 |
Rep 263
Drives: E46, E91, F21
Does your fan work at all? This sounds like your fan took a poop. See if it turns freely by hand, engine off of course!
06-29-2014, 10:08 PM | #3 |
863
Rep 5,448
I will check but was on the highway at 80mph which would generate more airflow than the fan would so it should not have overheated unless coolant flow is an issue, but would expect a code for something not working!
06-29-2014, 10:24 PM | #5 | |
Rep 263
If you don't then you may be safe to say that the pump is done. It may sound like its moving, however there may be no or very little movement of coolant causing the overheating that you experienced. If you do see coolant spraying, your pump may be still on it's way to the parts "round file." Or garbage can. Keep us on the update. |
06-30-2014, 06:33 AM | #6 |
77
Rep 339
You say the coolant itself is getting too hot, so you can eliminate water pump, t stat, air pockets, etc because those would cause just a general overheat to your engine. The problem is your coolant is passing through the engine and not getting cooled, which to me says there is a problem with the radiator. Anyone else agree?
06-30-2014, 05:47 PM | #7 | |
863
Rep 5,448
I think the pump stopped or thermostat stayed closed and just kept circulating coolant in the engine without going through the rad as once I pulled over and let it cool down to 210, I started it up to get to the exit ramp and after about 15 seconds, the temp dropped to 175, which would indicate that the cold coolant in the radiator suddenly started to circulate into the engine to drop the temp so significantly and so quickly, otherwise it would have just stayed at 210 which is about normal temp for my coolant. I also forgot to note, I have the electronic steering wheel, so it shows me cooland and oil temp both on the wheel. Drove it to work today, 6 miles each way, warmed up to a normal 210 or so and stayed there fluctuating between 205 and 212 max - no issues. Just can't help but feel it is an early warning sign, but wish it set a code, but may just replace the thermostat and pump since they are known to fail.
06-30-2014, 06:51 PM | #8 |
174
Rep 532
My gut is water pump (electric water pump) is on the way out and intermittently not working... Did you pull codes as to why / what?
Unlike basically any other car I've ever had, the water pumps do this before they completely fail... might be worth checking. |
06-30-2014, 08:24 PM | #11 |
863
Rep 5,448
Absolutely no codes (actually was disappointed - was hoping to get a code for the pump and then would feel better spending the 500 bucks!)
06-30-2014, 08:25 PM | #12 |
863
Rep 5,448
18,000 - just broken in (but 6 years old), a little early for a water pump, but have read of others as early as 9k miles.
06-30-2014, 08:26 PM | #13 |
863
Rep 5,448
Yes - thinking it is a warning from the bmw gods and I should listen!
08-10-2014, 06:42 AM | #14 |
Rep 154
Drives: 2006 e90
I know my fan isn't working, only do short runs in it, if I have to go further I use the wife's car... Fan cost was £400 so haven't bothered to get it done.
Does this affect the general running of the car? Tick over is not perfect at the moment, not bad just not 100%. Car has done 94000 miles. Because the fan isn't working I was wondering is this affects the flow of the coolant? |
09-11-2014, 08:18 PM | #17 | |
19
Rep 595
09-11-2014, 08:26 PM | #19 | |
108
Rep 474
09-13-2014, 04:27 PM | #20 | |
No 55mph
1622
Rep 8,476
If you remember, I had that finicky relay in my fuse box that was giving us trouble when installing the M3 Gages
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
09-13-2014, 07:15 PM | #21 |
19
Rep 595
09-14-2014, 02:29 PM | #22 |
No 55mph
1622
Rep 8,476
Coolant Temp info can be pulled off CanBus from OBD Connector under dash.
Both my P3Cars Vent Gage, & my New Dynavin N6 radio display Coolant Temp...
