Idle
06-29-2014, 09:37 PM | #1 |
413
Rep 1,362
Idle
Does your bmw idle this low?
I install bms pb when i startup the car was revving on his own... Remove pb is doing the same. Took car to bmw they say throttle and dmtl pump are failing 1.5k on parts and labor hell noooooooo Bought parts and will do the job my self..
06-30-2014, 12:48 AM | #4 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Mine does it but usually it's 725 that feels much better than when it hovers around 600.
07-13-2014, 11:19 AM | #5 |
Libertarian
132
Rep 1,577
Yep, same here. Drives fine though, I don't care if it revs a bit on its own... It just wants to GO all the time. Can't blame it!
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
07-13-2014, 04:41 PM | #6 |
35
Rep 1,652
Ha yeah. The way I see it if that's my biggest problem I can live with it. Can't argue with it, under extreme load, drives fine and doesn't miss a beat.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
07-13-2014, 05:28 PM | #7 |
78
Rep 375
Mine used to idle that low, then I replaced plugs and coils (85k miles) last week and now it idles around 750 for some reason. Otherwise there's no problems with the car at all, just thought it was weird.
