2008 vs. 2009 328i Coupe?
06-28-2014, 11:03 AM | #1 |
Aspiring 1'er
78
Rep 534
Hey guys, some of you might remember when I posted about what I should be looking to buy later in the summer, and that time is getting closer...I've broken my search down to 2007-2009 328i/xi coupes. Now, my question is, is it a better idea to go with the 2009? I've heard much better things about the 2009's reliability, but I was wondering what the differential in price might end up to be. Any thoughts? All ideas are appreciated! Thanks.
06-28-2014, 11:07 AM | #2 |
I have to return some video tapes
362
Rep 4,712
2009 isn't LCI. It was 2011 for coupes.
However, 2009 models are available with m-sport and a better idrive system.
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
06-28-2014, 11:10 AM | #3 |
Aspiring 1'er
78
Rep 534
06-28-2014, 11:18 AM | #4 | |
362
Rep 4,712
2009 - 2011 models look the same as 2007 and 2008, but got minor upgrades like the idrive (better controller, hd screen, more functions), instead of xi awd is called xdrive, and like I said the m-sport package became available in the US. I think 2010 models got bluetooth audio and new paddle shifters and 2010 models got new side mirrors 2011+ models are LCI. LCI was mainly cosmetic with new bumpers, headlights, and taillights. The 335i also got the new single turbo n55 (except in the 335is) to replace the twin turbo n54 found in older models
06-28-2014, 11:34 AM | #6 |
214
Rep 988
kdbryce, I think 2010 still got the push-pull paddles
2009 with sport/M-sport comes with black shadowline window trim, while all 2008s, regardless of spec, have chrome trim. I would get 2009 for the black window trim and the updated iDrive alone. |
06-28-2014, 12:05 PM | #8 |
7478
Rep 10,120
06-28-2014, 12:52 PM | #9 |
Aspiring 1'er
78
Rep 534
Yes that's what I'm hoping is around 60-75k, that'd be ideal as I'd still have comfortability to get all maintenance up to date. Do you think it'd be worth it to find an extra couple grand to find one with less mileage?
06-28-2014, 01:10 PM | #10 |
249
Rep 777
If you're going for a 328i, then you wont run into too many major issues. So 60k miles isn't bad. Now if you got an N54(2007-2010) 335, you're not going to want one with high miles.
06-28-2014, 01:20 PM | #11 |
Aspiring 1'er
78
Rep 534
Yeah, I've kind of moved away from 335i's as I'm 18, and don't want to be paying crazy bills every other week, and I'm just as satisfied with the 328's power honestly.
06-28-2014, 02:25 PM | #13 |
793
Rep 1,627
Try to find one that has had its water pump replaced already, not exactly a cheap fix but could be much worse if it does go bad..The valve cover gasket will likely go bad around 60-100K (BMW should have recalled both of these aforementioned issues). Also, you might want to avoid xDrive. my 07 328i's transfer case went bad at just 55K miles and have heard other stories of it going bad around that mileage. That would have been an expensive fix. Finally, I hope you plan on getting a manual gearbox because the slushbox is not only a poor design, it is fairly unreliable.
Someone with more experience can chime in here, but I believe BMW updated the stereo screen so the pixels didn't get washed out in the heat as they did in 2007 and 2008 models. Also, I believe BMW improved the water pump in 2009. Last edited by Vegetable; 06-28-2014 at 02:33 PM.. |
06-29-2014, 10:22 AM | #14 |
66
Rep 675
I dont know what type of research you have been doing BUT you will not find a COUPE for $15k . Not with 60,000 miles. The milage would be north of 85,000. A simple search on auto trader will show this. There is about a $2k gap between sedans and coupes.
