S55
06-27-2014, 05:06 PM | #1 |
Rep 107
S55
//M takes the N55, does their skunkworx, and voila - 430 at the crank.
http://www.bmwblog.com/2013/09/25/meet-new-s55-engine/ //M agrees that the twin-scroll is sub-standard for performance i want the exhaust side on my n55!!!!!!! 'TwinPower' now refers to both twin-scroll turbine and biturbo. It makes just as much sense as the nomenclature convention. Also, the F-series all have twin exhausts. suck it easy, BMWNA Marketing
2011 335xi
M-Tech | Koni Yellows | Alpina TCU | Injen CAI | JB4 | Ar resonsated 4" dp | PE Mod | LUX | Coded 2009 R1200 GS Adventure Prudhoe & Back. |
06-27-2014, 06:36 PM | #2 |
Rep 200
I don't understand...bmw engineered the N55 to be more efficient/reliable than the n54. Stock for stock it might even be faster... I'm not sure they were too worried about aftermarket performance. That being said, go buy a VTT stage 2 and call it a day.
06-28-2014, 01:30 PM | #4 |
Rep 107
i wrote a whole SWOT analysis of BMW's North American market. and then IE crashed.
i still have the wrong goddamn manifold and this silly twinscroll turbine. and the n54 still doesn't have ValveTronic. c'mon!
2011 335xi
M-Tech | Koni Yellows | Alpina TCU | Injen CAI | JB4 | Ar resonsated 4" dp | PE Mod | LUX | Coded 2009 R1200 GS Adventure Prudhoe & Back. Last edited by Knonsense; 06-28-2014 at 07:54 PM.. Reason: VANOS -> ValveTronic |
06-28-2014, 06:13 PM | #6 | |
72
Rep 436
06-28-2014, 07:54 PM | #7 |
Rep 107
2011 335xi
06-29-2014, 06:47 PM | #8 |
136
Rep 1,192
Drives: 2011 335i MT
I'm waiting for someone to figure out which S55 parts can be grafted onto the N55. It would be sweet if we could add OEM parts (e.g., bigger turbo) and get some nice gains.
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
06-30-2014, 01:20 PM | #9 |
32
Rep 373
The S55 is a crazy motor, Terry at BMS put down 427whp stock on a Dynojet, 479whp with a tune. This will probably be the next 2JZ...
2011 335i sedan 6MT, 515whp/530wtq. Pure Turbo Stage 2, Motiv SST TwinDisk Clutch/FW, Motiv Flash, AA 4" DP, ER FMIC, AA turbo-back exhaust, Quaife LSD, ST Coilovers, BMS Intake, UUC DSSR+SSK, ER CP, BMS CDV, BMS OCC, Arkym CF trunk
06-30-2014, 01:34 PM | #10 | |
71
Rep 510
07-07-2014, 09:44 PM | #11 | |
45
Rep 531
07-07-2014, 10:01 PM | #12 |
456
Rep 6,478
S54>2JZ. At this point the GTE is irrelevant outside of dyno graphs. Obviously at the time it was a new frontier, and it's certainly a horse of a short block.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
07-08-2014, 09:09 AM | #13 |
Rep 107
2011 335xi
07-08-2014, 10:06 AM | #14 | |
Rep 175
Drives: 2011 335i 6MT
The S54 isn't even that much lighter. |
07-08-2014, 10:16 AM | #15 |
7478
Rep 10,120
07-08-2014, 10:18 AM | #16 | |
456
Rep 6,478
The only people doing GTE builds are doing it for a dyno printout, magazine shoot, or cool swap. As an actual performance platform, it's been eclipsed by numerous motors and the chassis is no good. I'm not denying its' legacy in the tuning world, or the strength of the block. But in comparison to more modern platforms, it's heavy, inefficient, and hampered by awful OE fueling and command systems. There is absolutely no question that for an 800-1K WHP build that had any intention of actually being driven, S54>2JZ. Have you seen the spool on GTEs with those 76mm turbos? It's absolutely terrible.
07-08-2014, 11:02 AM | #17 | |
Rep 175
Certainly takes a while to spool but not ridiculous, it still makes more power than most cars by 4-5k rpms. In the supra with mostly stock supporting systems its not that great. The block is just bulletproof. |
07-08-2014, 12:17 PM | #18 |
32
Rep 373
Terry is now at ~530whp/570wtq running an ethanol mix
07-08-2014, 12:28 PM | #19 |
Rep 107
S54 is NA and based on the M54 - M for natural aspiration.
S55 is twinturbo'd and based on the N55 - N for forced induction. don't see how the S54 enters the convo about the hoped parallels between the N55 and the S55.
2011 335xi
07-08-2014, 12:41 PM | #20 | |
456
Rep 6,478
The S55 doesn't belong in the same zipcode of awesomeness as the S54. It's nice that we're seeing good power with piggybacks and octane, but that's not at all surprising for a factory boosted 6. Let's see when things start to fall apart, then we'll know what type of motor it is. I will say the curve looked pretty nice for stock turbos.
07-08-2014, 03:01 PM | #21 | |
Rep 107
Agreed. two times
2011 335xi
07-08-2014, 03:14 PM | #22 |
Rep 107
found different info towards same endstate.
S55 has different bore/stroke than N55, different block, etc etc. probably the end of N borrowing from S http://f80.bimmerpost.com/forums/sho...d.php?t=893611
2011 335xi
