06-26-2014, 09:20 PM | #1 |
156
Rep 1,288
Drives: 2014 435iX, FBO
M4 vs TRACTION
Just reading the C&D M4 vs 911 and the M4 vs F type reviews that are out.
Comments like: Coming out of a roundabout with the mildest bit of enthusiasm, two things happen: the amber DSC light flickers an admonishing warning And Out of the corners the DSC is flashing ever more insistently so I press the ‘M2’ button on the steering wheel, which has been programmed with the M Dynamic mode. This in theory allows more slip, but the M4 still feels shackled and the DSC light continues flickering whenever I get on the power out of corners. And the C&D M4 vs 911 Stating the trac light was lit up as the back end squirms... I have a modded 335 now, and I don't want to go to another car that can't get the power down. It isn't the fun I want. Admittedly, the M4 is the complete package... Always will be... But I want the power down and blast out of the round a bouts, corners and in the wet too. What are my choices? 1) 911 C4S - first choice bar none, get the wallet out for 110k used (canada) 2) GTR - not bad, but not the full package of luxury either. - same price as M4 though 3) RS5- bit cheaper than M4, will need supercharger maybe, and loss of feel. 4) wait for 4motion C63 new model if there is one 5) modded 435 x-drive like I have now, except x drive and add weight, and lots of modding to make the car what I want. Last choice for sure 6) S5 modded, but you can't get the power up enough Is this it? Anybody else not happy with traction?
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
06-26-2014, 09:37 PM | #3 | |
156
Rep 1,288
I am not sure I want the M now.... New quote from M4 vs F Type article: I stick with the BMW for the next few miles up the N2 and decide to turn DSC off completely. The first slide is a little tentative because it seems to initiate so easily that I’m worried it might get quite big quite quickly, but not so. And once you know how easy it is, literally every corner on the N2 seems to become an opportunity to get the rear wheels over-rotating. Load up the outside-front, then with the revs somewhere in the monstrous mid-range torque plateau (1850-5500rpm), simply press the throttle. There’s no need to stamp or mash the pedal deep into its travel because the M4 is already balanced in such a way that it’s just waiting for a nod of approval from the 406lb ft to tip itself into a slide. You’ll feel the rear go light and hear the revs rise as the tail steps out of line, but catching it is easy and the brilliant Active M Differential means your right foot is then the master in deciding how long the black lines behind you are going to be. Turning around and driving back down the road, I’m slightly shocked at just how many corners I seem to have tattooed with two long stripes of melted rubber. There’s one particular slide through an uphill right-hander that I’ll remember for some time, because it just seemed to go on and on and on. I turned in early and almost immediately had the car oversteering, but sweetly rather than luridly. It felt totally in control all the way through the corner, right foot keeping the slide going but in check on my side of the road, just an eighth of a turn of opposite lock dialled in and the razor-sharp throttle managing the rear axle every bit as precisely as in the V8 E92. All the time the M4 was accelerating through the corner feeling both balanced and infinitely more balletic than I would have believed possible after the initial drive this morning.
06-26-2014, 09:50 PM | #4 |
demoted
453
Rep 1,172
Definitely an issue...
Right now I'm fairly happy with the 435i xDrive 8 AT w/ MPPK. The only thing I really miss from my 2010 M3 DCT is the handling, and I expect that PSS tires and Dinan springs and Shockware would solve that.
But obviously you're looking for more drivetrain performance, and you're right that this is not a promising route; and not one I'll likely stick with either. So when I get bored in a couple of years I expect to buy an M4. I just don't see a viable alternative right now. |
06-28-2014, 10:33 AM | #5 |
410
Rep 1,025
This is an expected, but fixable problem. I would bet that the rear fenders will fit at least a 295 tire. I'm sure BMW will address this if they do a competition pack, which they likely will, with wider tires resulting in better power delivery out of turns and off the line. We might see 0.2-0.3 seconds shaved off the 0-60 and quarter mile from just tires, and more with a more aggressive tune.
06-28-2014, 11:00 AM | #7 |
51
Rep 551
There is a lot of power which is obviously a good thing but in the rain even in a straight line traction is an issue. Looking at 1:36 of this video the DSC light is flashing but the M4 does seem to be perfectly in control though. I would imagine in the rain around a corner extreme caution would be warranted with the DSC turned off or partly off.
06-28-2014, 03:16 PM | #8 |
25
Rep 146
Traction control in m3 is extremely aggressive. It keeps interfering and you have to either use mdm or turn it off.
Old m3 or new m5 werent like this. Car makes too much power in rear wheels and torque for its weight and chassis setup. |
06-29-2014, 06:22 AM | #9 |
73
Rep 963
On dry roads your ability for outright grip under power is based on the coefficient of friction of rubber on tarmac, with 1 being the max without downforce. In fact because it is directly proportional to the force, and the force is inversely proportional to the area of the tyre which spreads the lead, then in a model that ignores the effect of rubber bonding with tarmac...adding more tyre width actually doesn't change available grip!!!!
Width helps behaviour as the slide develops though because the sheer forces between the two surfaces increases! A wider tyre might hang on longer than a narrower tyre but will be snappier and once it let's go the wider tyre has more traction. But until then they're the same. This is actually mostly independent of the car but is dependent on the tyre, which as we know is the single most important component on our cars except ourselves When the road is wet forget all of the above. If wet behaviour is your target get an Audi or a GTR instead as that coefficient of friction cross from 0.8 or whatever down to 0.2 or 0.3 regardless of whether you have a Ferrari or a 2CV. The only difference being the amount of torque available to break that sheer force and to get you into trouble. Last edited by crypticc; 06-29-2014 at 09:35 AM.. |
06-29-2014, 10:03 AM | #11 | |
Enjoying driving
388
Rep 1,169
06-29-2014, 05:22 PM | #12 | |
73
Rep 963
06-29-2014, 07:29 PM | #13 | |
Enjoying driving
388
Rep 1,169
07-01-2014, 04:32 PM | #15 | |
230
Rep 3,899
I find short shifting in gears 1 and 2 helps.
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold 2010 JZB E90 M3 DCT - Sold 2009 6MT E90 LCI 335i M -Sport - Sold |
07-02-2014, 02:26 AM | #16 |
IS350 to IS-F to M3 and M4
117
Rep 803
I've had an M4 for a about 12 days now, and while I've not pushed the car too hard to respect the redline during engine break-in. I've not noticed too many problems with DSC intervening. Of course after the 1200 miles service, when launch control is available, will be the real test.
Hoping the journalists were past the 1200 mile mark on their drive. |
07-02-2014, 07:18 AM | #17 |
767
Rep 1,683
That's exactly the reason I ditched my E92 M3 and went with the RS5.
The M3 wouldn't go anywhere in slow corners or roundabouts, traction was a big issue up to the 3rd gear. Went to RS5, let me tell you this car is an animal on take-off, slow corners and roundabouts. And there is no feel lost with the RS5, this is very similar car with the E92 M3, just with improved traction...if you really push the RS5 mid-corners it goes in oversteer big time, until the front wheels cath-up the traction.
22 M4 Competition xdrive
19 M5 Competition sold 16 F-Type S AWD sold 11 Audi RS5 Misano Red--sold 08 E92 M3 Jerez Black 6MT--sold 08 E92 335i 6MT traded in for M3 |
07-02-2014, 08:59 AM | #18 |
Rep 491
It makes perfect sense for BMW to be overly conservative with the traction control system, especially in the "legal-happy" world we live in.
Let's not forget that it does take a certain degree of skill to drive a 400+hp RWD car without spinning out like crazy. Personally I'd be more concerned if track testers are having issues keeping the rear in check than a journalist on the street. |
07-02-2014, 02:06 PM | #19 | |
156
Rep 1,288
My modded 335 just spins.... and I have the LSD and all the stability bits. I could do more, but I won't spend another penny on this car. I'll save for my next car. I don't want to spin. I want to blast out of the corners and I think that means all wheel drive. Then I get the wet traction and snow as well.
07-02-2014, 02:09 PM | #20 | |
156
Rep 1,288
Do you find the RS5 fast enough? I have been doing a lot of research on the RS5 too. The reports are pretty good and comparable to the E92 M3, except for steering feel. I may have to trade that off for traction and winter/bad weather benefits - your thoughts on this? You feel you are losing anything going to a RS5?
07-02-2014, 10:17 PM | #21 |
Rep 98
OP: If traction is a concern on the M4, I would add two cars to your list of options: GTR as mentioned, or STi if you want a manual. STi is not luxury (but is quite comfortable for basically a race car), but has AWD, torque vectoring and an adjustable differential, and only comes in a 6 speed manual.
07-03-2014, 07:39 AM | #22 | |
156
Rep 1,288
