06-26-2014, 03:41 PM | #1 |
Rep 33
Drives: 2014 435i M Sport
HOLY Brake Dust Batman!!
I know I know, BMW's are known for producing lots of brake dust but I just got my 435i on Monday and it's INSANE how bad the rims look. I have the upgraded M Sports brakes and expected some dust but will 200 mile on it I need to know what you guys are using to fight this other than elbow grease?!
06-26-2014, 04:30 PM | #2 |
61
Rep 702
Chemical Guys Diablo wheel gel to clean, and Chemical Guys Wheel Guard sealant to protect and reduce brake dust buildup
http://www.chemicalguys.com/default.asp My wheels stay pretty much totally clean looking between washes
2014 BMW 328i Sportline--Arctic White/Black, 8 speed
06-26-2014, 04:35 PM | #3 |
Rep 33
Thanks! Looks like I'll be spending quite a bit on this site
06-26-2014, 05:23 PM | #4 |
130
Rep 1,101
Get the Diablo cleaner and the sealant as ZENABIMMER recommended. Also get a EZ detail brush like this:
http://www.detailedimage.com/DI-Brus.../Mini-Size-S2/ The Diablo wheel cleaner I dilute 4 parts water - 1 part diablo gel. It still works great and lasts a long time. Spray it on, give a brush and rinse. I tried Sonax wheel cleaner. Looks cool as it changes colour. It does get off a fair bit of the brake dust on its own. However, I found it needed a few applications or a brushing to get the wheels clean. That stuff is $$$. Just stick to Diablo cleaner and the brush. |
06-26-2014, 05:25 PM | #5 |
Rep 33
Brush looks good. I'm on CG's now debating on getting one of those foam guns. They look awesome.
06-26-2014, 07:54 PM | #6 |
306
Rep 1,741
Have you actually tried cleaning them yet? They look bad, but it wipes off pretty easily with just a wet soapy sponge. That's assuming you can get into all the nooks and crannies.
06-26-2014, 08:02 PM | #7 |
Rep 33
Yeah I was out today and cleaned them. Didn't want the dust to cake too bad in the heat. I have the 19s and there's a really tight spot on one spoke. But I ordered a few things from CGuys today. Thanks for the links
06-26-2014, 09:42 PM | #8 |
61
Rep 702
No problem! Chemical Guys products are fantastic, and it becomes an addiction! ;-)
The foam gun is very cool, but I'd only get one if you have a pressure washer to hook it up to. If you do get one, make sure you let the foam dwell for a few minutes, then power wash it off before cleaning with the normal two bucket method, that way the foam is allowed to pull most if the dirt and debris off the paint, thus minimizing the chances of scratches using the wash mit. Some people make the mistake of using the wash mit with the foam caked on the car, and that's just likely to scratch the debris that the foams lifted right back into the clear coat. Chemical Guys have hundreds of fantastic demonstration videos on their YouTube channel that you should also check out
06-27-2014, 05:57 AM | #9 |
1999
Rep 6,916
take a look at
Sonax Full Effect Wheel Cleaner and Sonax Wheel Cleaner Plus Wheel Woolies EZ-Detail Brush Auto Finesse Hog Hair's Brushes Video it would not be a bad idea to protect the rims with a wax or even better a coating. some suggestions Auto Finesse Mint Rims Sonax Polymer Net Shield Opti Coat |
06-27-2014, 09:40 AM | #10 |
436
Rep 942
http://f30.bimmerpost.com/forums/sho...termarket+pads
M Sport and M Performance brakes are identical on the 335i and 435i, except for the dimpled/slotted rotors. |
06-27-2014, 12:25 PM | #11 | |
Rep 33
06-27-2014, 01:14 PM | #12 |
306
Rep 1,741
That picture looks like some serious road rage occurred...or someone drove through a vineyard.
THose who have used power washers...are these the standard ones that you use to wash your deck or siding with? If adjusted up to mid pressure, it'll rip right through skin (yes I know that for a fact ) How do you make sure you don't screw up and blast the paint right off?? |
06-27-2014, 09:33 PM | #13 |
11
Rep 38
Drives: 2021 M3 Comp.
Try This Out...
As a proud owner of five previous Bimmer's (435 vert is due in any day now from a fun ED at the Welt) I understand the desire for our rims to always look good. Here's my secret weapon - I use a dry car wash mitt (not expensive) every other night on the rims. My hands never get dirty, the rims look great and when the mitt's dirty I just throw it in the machine. Hope this helps someone.
06-27-2014, 09:36 PM | #14 | |
61
Rep 702
06-27-2014, 10:01 PM | #15 | |
Rep 33
06-27-2014, 10:17 PM | #16 |
11
Rep 38
Try This Out (w/a Pic)
Nothing fancy, but it works brilliantly...
http://f30.bimmerpost.com/forums/att...1&d=1403925270 |
06-27-2014, 10:19 PM | #17 |
11
Rep 38
Scratches?
Good question. I wash the mitt every other week and I've never had an issue with my rims being scratched.
06-28-2014, 12:49 AM | #18 |
61
Rep 702
Brake dust is very abrasive, I'd be worried about scratching the wheels. At least make sure to spray a quick detailer first for some lubricity
06-29-2014, 04:13 PM | #19 |
175
Rep 766
I use sonax right now but am looking for something a bit cheaper. It does come off very easily if you stay on top of it ie I clean my wheels once a week. Using the pressure washer at the self-serve car wash. I just spray the Sonax on, let it do its work then use the high pressure rinse and the wheels are sparkling. No brushing at all.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK Last edited by MickAv8r; 06-29-2014 at 04:39 PM.. |
07-02-2014, 07:52 PM | #20 | |
1999
Rep 6,916
or we have Buy 5 get 1 free deals going on. |
07-10-2014, 04:18 PM | #21 |
_________
16
Rep 216
I've been using the Chemical Guys Wheel Guard and it works pretty well. I just wash the car as normal, then to finish up apply the paste, then remove. It takes the grime & dust off as well as shines in one step.
So far, I've had less dust accumulate on the wheels, and for the most part - they have retained a nice polished sheen. We'll see how long it lasts. |
07-10-2014, 05:19 PM | #22 | |
61
Rep 702
