My Airplay Install/Review
06-25-2014, 08:52 PM | #1 |
129
Rep 1,052
Using posts I found here, I installed the AirEnabler Airplay device into my car. I'd like to thank the OP in the DIY section for the inspiration.
It was pretty easy. The only hard part was getting the router into that small area with the connections I had. I secured it in place with some of that 3M gray all weather mounting tape. The super sticky stuff with the red backing. I also used a FiiO e10 USB Headphone Amp/DAC unit. I think FiiO has discontinued this model now and that's a super shame because I've been using it at my desk for the last year and it's really a great little piece of kit. (I upgraded to Schiit Audio amp and DAC components at my desk today so I had this FiiO to use) Having the FiiO in the loop makes this Airplay solution the total package. It makes the HiFi system sound 10x better when being used through the AUX jack. Can't say much for the DAC that came with the AirEnabler kit, it didn't sound very good, nor did the Creative Labs DAC the AirEnabler website suggested. Stay away from that thing. God awful. Overall I'm really impressed with this. I might order some thinner right angle USB cables from Monoprice to clean it up a bit more... Here's some pics.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White |
06-26-2014, 12:01 AM | #3 |
129
Rep 1,052
It gives your car an apple airplay wifi connection so you can stream your music from your idevice to your car stereo losslessly and with improved audio quality over stock if you get a decent portable amp/DAC as I described.
You should check out the manufacturer website. Google airenabler.
06-26-2014, 09:45 AM | #4 | |
129
Rep 1,052
A higher quality DAC will do a better job of converting the digital signal your music player device sends out into the analog signal needed for speakers, with a more accurate reproduction of the original sound. The amp portion of that allows you to maintain that sound accuracy and increase the volume without distortion. What I'm using is a decent USB powered DAC/Amp combo unit that was built for headphones and portable speaker systems. There's a big difference in the depth and richness of the music vs the stock USB DAC that comes with the AirEnabler which sounded tinny and flat IMO.
06-26-2014, 09:59 AM | #5 | |
129
Rep 1,052
Being that this guy basically hacked the firmware in this tiny router to make it airplay compatible so I can put it in my car, I don't even care about that hehehe.
06-26-2014, 10:16 AM | #6 |
103
Rep 2,783
Why not use airport express?
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
06-26-2014, 12:16 PM | #9 |
129
Rep 1,052
Cool. I used a bluetooth dongle like Kinivo BTC450 or xtrememac InCharge AutoBT for the last year, but overall the BT audio quality can't touch the lossless playback of Airplay, which is why I went this route.
06-26-2014, 12:18 PM | #10 | |
129
Rep 1,052
06-26-2014, 12:21 PM | #11 |
129
Rep 1,052
You can, but...For me it was more expensive than this solution (since I already owned the DAC/amp I used). Bigger in size. Requires changing the power adapter out for a USB power cord which requires soldiering and getting a power step-down converter.
You also need to open the Airport Express which instantly voids its warranty. Big fan of AirPort stuff though. Use it all over my house exclusively.
06-26-2014, 03:35 PM | #13 | |
129
Rep 1,052
Also tested with voice dictation on iPhone, same thing.
06-26-2014, 03:53 PM | #14 |
1274
Rep 4,703
06-26-2014, 05:55 PM | #15 |
1910
Rep 3,218
Drives: 2018 BMW 440i GC
I would like more info on how to do this with airport
06-26-2014, 07:59 PM | #16 |
129
Rep 1,052
Google e90 airport airplay and you get the following first hit:
http://www.e90post.com/forums/showthread.php?t=908456
06-26-2014, 08:18 PM | #17 | |
1910
Rep 3,218
06-27-2014, 01:14 PM | #19 |
129
Rep 1,052
Cool. Again credit goes to the OP in my link in my original post here. Just thought posting it again with my modifications would help introduce this to more people.
07-02-2014, 02:19 PM | #20 |
16
Rep 376
07-03-2014, 12:38 AM | #21 |
121
Rep 876
I did this mod few months ago...sounded decent with upgraded Behringer DAC...hardwired it to fusebox for power.
I have since moved on to Kivic One...got audio to work fine(doesn't sound quite as good as AirEnabler with upgraded DAC) but this theoretically allows airplay mirroring..so video, apps and etc seen on iPhone can be seen on NAV screen. Not as easy as I thought as my first solution did not work..doing some more due diligence on the subject now. |
07-03-2014, 05:50 AM | #22 |
255
Rep 2,547
I'll be installing a dsp that has an auxiliary optical input as well as the standard rca. The rca will get inputs from the head unit but would like to feed the optical from an airplay device. Does anyone know how I could get optical out from this air enabler?
