Brake disc's
06-25-2014, 10:25 AM | #1 |
48
Rep 573
Brake disc's
I know in an ideal world brakes and discs would be changed at the same time.
But do these discs need changing or can I get away with just pads?
06-25-2014, 11:11 AM | #2 |
140
Rep 1,445
What's the inside face like?theres a bit of a lip on them too.If you can get a set of Verniers measure the thickness.The minimum is stamped onto the disc hub itself.how many miles have they done?
06-25-2014, 03:46 PM | #4 |
529
Rep 2,503
As a above, depends on what thickness they are at. I've seen worse. The lip doesn't look too bad. Although if you are doing the pads the discs aren't too much more effort.
06-25-2014, 03:58 PM | #5 |
37
Rep 408
Yeah, I didn't even have to remove my calliper mount. V easy job. Just make sure if you don't change them that they will safely last you until your next pad change.
