Jack Pads
06-24-2014, 10:26 AM | #1 |
26
Rep 122
Jack Pads
Not trying to sound cheap, but for the occasional diy work, like brakes and oil, will i notice enough of a difference between the name brand 20+ per pad like burger motorsports or ecs branded jack pads, vs the cheaper no names from ebay that cost 32-50 bucks for a set of 4?
I was thinking about getting either http://www.ebay.com/itm/BMW-JACK-PAD...3D200933359265 or http://www.ebay.com/itm/BMW-Jack-Pad...db171d&vxp=mtr Thanks in advance, Jeremy |
06-24-2014, 10:57 AM | #4 |
87
Rep 422
One thing that i wish the jack pad could do it swivel somehow.
If you don't understand... Lets see how I can explain this. Unless you are jacking the car from all four corners at once -- the BurgerTuning jack pad (which I have) is great, but when you just jack up the front or rear or side by itself -- the jack pad tilts on the jack and could slip. It hasn't happened to me yet -- but it is precarious.
I am just here to help! |
06-24-2014, 07:04 PM | #7 |
Rep 284
I've got one of these. I liked the rubber bumpers on the ends that hold the adapter in the jack pad so you can just raise the saddle of the jack up to meet it. It's nice, but in reality though I haven't used it. The car sits low enough that my jack won't clear for the front lift points. More recently I had a few pieces of hard wood cut down to fit instead. They're dirt cheap, work with jack stands as well, and extend only barely below the bottom of the jack pad.
06-24-2014, 09:25 PM | #9 |
17309
Rep 18,733
Just jack the car up using the center jack points and set it down on the side lifting points (what you call the jack pad). This is the correct way to lift the E90 chassis.
06-25-2014, 02:01 AM | #10 | |
129
Rep 1,052
This is the proper way to lift your e90. Center jack points then slide jack stands under your side jack points. I use a hockey puck with my jack to lift at the center jack points for a little extra height. |
06-25-2014, 06:43 AM | #11 |
103
Rep 2,783
After jacking it up, does anyone use anything on their horses? The horses can damage the jack pads too.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
06-25-2014, 09:10 AM | #12 |
87
Rep 422
What does it look like? I have been under the car a few times but have not noticed a center jack point. Maybe since I wasn't looking...
06-25-2014, 09:22 AM | #13 | |
39
Rep 315
Open the attachment from the OP. There is a jack point in the front and you can jack it in the rear using the rear differential. However, DO NOT jack it up using the differential cover!
07 335i
Mods: JB4 + MHD BEF, RB Twos Plus, Phoenix PI Manifold, Dual Walbro 450 LPFP's, DCI, VRSF DP's, VRSF 7.5" FMIC, VRSF CP + TiAL BOV, VRSF inlets & aluminum outlets, TC Kline SA, M3 F/R control arms, M3 subframe bushings Last edited by Zach1328; 06-25-2014 at 09:30 AM.. |
06-25-2014, 01:00 PM | #14 |
129
Rep 1,052
You don't want to use the diff. Use the black metal brace that comes across the car that sits in front (if you're looking at the car from the back) and above the diff.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White |
06-25-2014, 04:12 PM | #15 |
17309
Rep 18,733
You can use the cast iron differential housing, just not the aluminum diff cover. This per BMW's recommendation.
06-25-2014, 04:14 PM | #16 |
17309
Rep 18,733
The rear is the diff housing. The front is the approx. 5" round indentation in the belly pan with the rectangular metal piece in the center of the indentation that has a bolt hole in it.
06-26-2014, 04:08 PM | #17 | |
87
Rep 422
Where else can I get something like this? Edit: Plastic Jack pads not the aluminium. I already have the aluminium one from Burger Tuning.
I am just here to help! Last edited by JoeyH335i; 06-26-2014 at 04:14 PM.. |
06-28-2014, 09:50 PM | #19 |
21
Rep 677
i made some like these
http://www.e90post.com/forums/showthread.php?p=12723386 but i used a piece of wood in the center. and drilled it into the puck to hold in place. |
