08 BMW 335i oil recommendation?
06-22-2014, 08:21 PM | #3 |
Curmudgeon and Pedant
690
Rep 3,489
06-22-2014, 09:58 PM | #5 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
OEM LL-01 comes in 5w-30. Mobil 1 LL-01 Euro is 0w-40 either way most important thing is you change it at a decent interval.
06-23-2014, 07:04 AM | #7 |
26
Rep 199
06-23-2014, 08:32 AM | #8 | |
690
Rep 3,489
The differences are small, and there is no doubt that people have run non-approved oils in these engines successfully, but are you going to risk a $25K engine by saving $5 each oil change? Are you a mechanical-chemical-electrical-metalurgist engineer that designs engines? Didn't you buy a BMW because you like the cars and engines that their engineers designed and specified out in every detail? Using your "favorite" oil is due to marketing; using a BMW-approved oil is science/engineering and marketing. |
06-23-2014, 11:29 AM | #9 |
296
Rep 2,015
06-23-2014, 07:34 PM | #11 |
35
Rep 1,652
Correct.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
06-23-2014, 10:04 PM | #13 |
95
Rep 442
Drives: 11 335is Coupe BSM
Redline, Royal Purple, Pennzoil Ultra Euro, or Liqui Molly 5W30 - but to tell you the truth you can use any oil cheap or expensive if you change every 3k miles. I use Redline now.
'11 BSM DCT 7 Spd. 335is | RPi | aFe Magnum Flow Direct Fit | Interad DTM 10 Forged | Smoked Reflectors | Huper Optik Tint | Arkym Rear Diffuser | Cyba CF Quad Tips | iND CF CRT Rear Spoiler | COBB Protune | Turbosmart BPV | AutoCarbon CF Grills | Silver CF e-Brake | BMW CF Mirror Shrouds | M Perf. Steering Wheel v2 | KW DDC Coilovers w/WLAN | Interior Xenon LEDs | Custom 335is Accents | F/R Fenders Rolled & Pulled | New Pipes Baffle Delete
06-23-2014, 11:09 PM | #16 |
35
Rep 1,652
06-23-2014, 11:32 PM | #17 | |
149
Rep 1,995
Tons of people running around in civics, gms, fords neglect the shit out of their car and might run 20k before an oil change. Don't see those cars exploding. Have a little faith in the oil and the car.. |
06-23-2014, 11:36 PM | #18 |
Libertarian
132
Rep 1,577
Mobil1 0W-40, every 7,500-8,000 miles.
In my case, my next will be the high mileage variety.
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
06-24-2014, 12:57 AM | #19 |
129
Rep 1,052
I've been doing Mobil 1 0W-40 as well in my 328. Every 5-6K miles.
Not because I don't think the oil doesn't last longer than that, but because I don't trust filters for longer than ~7500mi based on conversations with 2 lifelong BMW/Porsche mechanics with 50+ years of combined experience. I plan to keep the car until it doesn't drive anymore so I do it early, and have piece of mind that everything is fresh. Also installed a GoldPlug magnetic plug last time I changed. |
06-24-2014, 07:57 AM | #20 | |
26
Rep 199
I was looking for the details that made LL-01 different from other syns, which you provided in the initial paragraph. I prefer an eyes wide open view of the world and don't always believe that every "requirement" from an OEM is a minimum guard band. These same engineers are constrained by a multitude of variables -- not all of which result in their best foot forward for Customer use, e.g. HPFP, turbo wastegates, etc. Appreciate the response. |
06-24-2014, 09:50 AM | #21 |
Is it the shoes!?
3884
Rep 5,112
Dealer oil, because it's the best bang for your buck. You can find it for $7.95 at the dealer, or $6-ish with a CCA discount. The stuff is made by Castrol (for now). It's well-designed.
06-24-2014, 09:51 AM | #22 |
441
Rep 1,347
