2010 E92 under seat woofer replacement
06-21-2014, 11:34 AM | #1 |
The dude abides
50
Rep 265
I've got the drivers side woofer enclosure removed, but the screws which hold the woofer into the enclosure aren't used on my enclosure. There are a couple of plastic tabs which appear to be holding the driver in place, but so far no luck extracting it. And I don't want to break anything.
Any ideas? Example: Mine: |
06-21-2014, 11:53 AM | #2 |
69
Rep 994
Yea, it's adhered into the enclosure. Two options--heat gun and pry it out, or cut it out with a jig saw. We choose to go the heat gun route and pry it out at the shop.
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
06-21-2014, 01:08 PM | #3 |
69
Rep 994
My inbox is full and I can't delete messages til I get to the computer
06-21-2014, 02:08 PM | #4 |
300
Rep 3,969
"Pry like it's not your car" - VP Electricity
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
06-21-2014, 02:53 PM | #5 |
The dude abides
50
Rep 265
06-21-2014, 08:49 PM | #6 |
136
Rep 1,192
Drives: 2011 335i MT
The older ones had screws so some have bought older enclosures on ebay.
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
06-22-2014, 08:49 AM | #7 |
The dude abides
50
Rep 265
Got the Focal 100krs components into the doors, the SWS-8s are under the seats, all of the wiring is run but not connected. Smoke test this morning and if all works as it should the amp & processors will get mounted.
06-30-2014, 08:32 PM | #8 |
11
Rep 79
I have the same issue. Can someone also help confirm if the logic 7 or 8 inch woofer enclosures fit the same? I noticed they look different that the base one seen above. Thanks.
