Would a fender roll help here or it would still rub? Pics Included
06-20-2014, 09:50 PM | #1 |
121
Rep 774
Just added 15 mm spacers would a fender roll help the rubbing or 12 mm spacer and a fender roll?
06-20-2014, 10:07 PM | #2 |
Rep 53
I was sitting the same when I added my 15mm spacers but I have a 265 tire. I rolled my fenders, added some camber and now only rub when fully loaded and hit major bumps or hard turns. So a roll and some camber should work. If youre still rubbing drop down to a 265 tire and youll be good to go.
06-20-2014, 11:58 PM | #4 |
121
Rep 774
Its pre lci, also in the pics I parked the rear tire on a speed bump at a angel to allow it to compress more than on level ground. How many of guys had the fenders rolled and cracks showed up in the paint? Only reason am on edge about rolling fenders ?
06-21-2014, 02:11 AM | #5 |
98
Rep 477
Chances are it still may rub, had this problem myself.
Best thing might be to just sacrifice alittle bit of the looks and swap the 15s with maybe a 12mm spacer instead.
Follow My e92 335 AW- SNOW WHITE PROJECT BUILD
http://www.e90post.com/forums/showthread.php?t=952654 photo uploading websites |
06-21-2014, 12:04 PM | #6 |
76
Rep 916
Will rub ..I tried to even modify my own suspension to accommodate an aggressive offset and it rubbed on every little dip. Fender rolling only provides so much. Go with a smaller spacer and spare yourself the aggravation. I have to paint the wheel side of my fenders now because paint rubbed off.
06-22-2014, 12:55 PM | #8 |
121
Rep 774
Yeah am going to go with a 12 mm and a fender, hopefully thats enough. But the pics i took was pretty much at 80% compression and it mainly seemed to make contact with he fender. Lame thing is i was able to get away with 15 mm up front and a 245 which makes it look really aggressive but the rears kill the stance a bit.
