Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > E92 335i Dyno result
      06-20-2014, 01:54 PM   #1
Cerbera9
Drives: E92 335i 2007
Hi guys, here are my results of the dyno session I had at Alan Jefferies Enginetuner in Plymouth today.
i've got the following mods;
JB4 G5 (Map 5)
VSRF Catless downpipes
VSRF FMIC
BMS DCI's
BMS N54 Chargepipe
Forge DV's
Stage 1 Hybrid Turbos
Quad Exit back box
Cae run on Shell V-power 99
Dyno Dynamics 4wd dyno. All runs were in 4th gear (MT)
So using the autotuning in Map 5 (boosting to around 15psi) it made 429.5bhp and 490lb/ft and the crank.
[u2b][/u2b]
attachment.php
      06-20-2014, 02:31 PM   #2
phil200tdi
phil200tdi's Avatar
112
Drives: 335i M Sport E90 LCI manual
Whose turbos? I'd hope for more with hybrids... Only 10-15hp more than stock turbos.
On a dyno I'd be running map 2 for consistency. You might want to consider a back end flash too..
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft)
      06-20-2014, 02:43 PM   #3
Cerbera9
They were built by The Turbo Unit.
What torque do stock turbos usually make?
Do you think Map 2 would of produced better results then over Map 5?
      06-20-2014, 02:45 PM   #4
Sparky68
Sparky68's Avatar
684
Drives: 2016 M2 Alpine White
2016 BMW M2  [0.50]
2017 BMW F30 330D  [0.00]
2014 M135  [0.00]
2007 BMW 335i  [0.00]
What spec are the turbo's? Still a nice result but as Phil said would of expected more.
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
      06-20-2014, 02:50 PM   #5
Cerbera9
Just a mild stage1 with slightly larger billet compressor wheels.
I'll try Map 2 next time.
      06-20-2014, 02:52 PM   #6
phil200tdi
phil200tdi's Avatar
112
Very good torque to be honest.
I suspect you had a slight timing drop (from autotuning) in the mid range and this impacted the peak number. To be honest dynos don't reflect the road all that well...
I reckon with a back end flash (free software) you could get a very nice gain.. More so with meth!!
      06-20-2014, 02:54 PM   #7
phil200tdi
phil200tdi's Avatar
112
Did you log the runs?
      06-20-2014, 03:31 PM   #8
Cerbera9
Unfortunatly i didnt log the runs it was all a bit of a rush tbh.
I'm I'm new this year to the 335i N54 motor so I'm not looking to wring the neck out of the engine as I don't think the clutch will take much more tbh, but would be interested in the backend flash in the future maybe, what sort of gains can be made?
A friend runs Meth on his Audi S4 and rates it highly
      06-20-2014, 03:33 PM   #9
Cerbera9
I'd be intested to see more dyno print out from similar 336i JB4 cars ?
      06-20-2014, 03:33 PM   #10
Sparky68
Sparky68's Avatar
684
2016 BMW M2  [0.50]
2014 M135  [0.00]
Take much more? Guys in the US running 600bhp +
      06-20-2014, 03:34 PM   #11
Sparky68
Sparky68's Avatar
684
2016 BMW M2  [0.50]
2014 M135  [0.00]
I reckon you could squeeze a bit more out of it.
      06-20-2014, 03:36 PM   #12
Cerbera9
600bhp + on a standard clutch???
      06-20-2014, 03:41 PM   #13
Cerbera9
Do you think Map 2 would give slightly better figures then?
      06-20-2014, 04:05 PM   #14
rufnekfatboy
13
Drives: 335i M Sport Conv
Phil(the knowledge)200tdi... I have read lots of stuff you put on here...
This man knows his stuff, very impressed....
After reading, thought I had better ad that Sparky knows his stuff too...
      06-20-2014, 04:07 PM   #15
phil200tdi
phil200tdi's Avatar
112
Not stock clutch
With 490lb ft it'll have a limited life.. Mine made 510lbft and I replaced the clutch soon after!! Now running a spec stage 2+ Clutch and all good..
      06-20-2014, 04:54 PM   #16
Cerbera9
Did you stay with the standard dual mass flywheel or switch to a single mass flywheel/
      06-20-2014, 05:09 PM   #17
phil200tdi
phil200tdi's Avatar
112
Oem flywheel.
It's fine unless going serious hp.. The smfw's chatter which would be unacceptable..
      06-20-2014, 05:11 PM   #18
phil200tdi
phil200tdi's Avatar
112
Not really...
Just owned the car along time and experienced most of the n54 weak spots!! Plus I've pushed things hard.
      06-20-2014, 05:26 PM   #19
idnan
idnan's Avatar
England
76
Drives: Alpine White 335i
Its' all about fuel, our 99 v power isn't anything special
Run meth and wake those hybrids up!!
      06-20-2014, 05:54 PM   #20
rufnekfatboy
13
Not really...
You know more than most mate...... Not blowing smoke up but, you know your stuff so just thought I would say....
      06-21-2014, 02:42 AM   #21
Cerbera9
Sounds like Meth is the next step then, I'll look into it, cheers guys
