Help With Major Issue!!!
06-19-2014, 06:14 PM | #1 |
18
Rep 283
Can anyone help me out with this idling issue that is causing me to have limp mode active? The bouncing only happens when I press the brake pedal. After that if I let off the brake the car starts to sputter and run bad. I'm about to plug it in to inpa but I need more help. Thanks to whoever chimes in!
335i Coupe 6MT Montego Blue
06-19-2014, 06:48 PM | #2 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
a) how long ago did this start?
b) is it consistent, every time you turn on the car? c) what is the last major maintenance you did? d) let us know what codes you can pull with INPA.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
06-19-2014, 07:14 PM | #3 | |
18
Rep 283
a) started 3 days ago when I attempted to install the jb4 pinout. install went fine. After install was in limp mode. since then i have uninstalled pinout and put it back to stock. b) it's consistent for as long as i want to run the car which hasnt been long because i dont like running it in limp mode c) last major maintenance was coolant flush (replaced my whole radiator) and an oil change im at 100k miles d) trying to recover my old version of inpa that worked perfect (dad wiped the computer) __________________
06-19-2014, 07:29 PM | #4 | |
35
Rep 1,652
That has to be more than a coincidence. Unfortunately, I installed the COBB so I have no experience with JB4 (main reason i stayed away was i didnt want to mess with the DME).
WARNING - twisted JB4 DME cables can cause limp mode! Maybe you just need to go back and double check the wires? Sorry man, GL. just throwing ideas out. Oh yeah, see what's up with reading the codes if you can and let us know. Quote:
06-19-2014, 07:43 PM | #5 |
58
Rep 665
You should have mentioned that little detail in your original post. Chances are you either have a subconnector reversed, misaligned, or bent a pin. If you reversed a subconnector during the JB4 install and then went back to stock, that subconnector is probably still reversed.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
06-20-2014, 05:50 PM | #7 | |
413
Rep 1,362
06-21-2014, 10:16 AM | #8 | |
18
Rep 283
THANKS
06-21-2014, 10:25 AM | #9 |
Libertarian
132
Rep 1,577
Damned pins!
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
06-21-2014, 11:34 AM | #11 |
35
Rep 1,652
Nice! Glad it's solved. So you put the jb4 back on now that you figured it out?
06-21-2014, 12:09 PM | #12 | |
58
Rep 665
08-09-2014, 12:02 PM | #14 |
18
Rep 283
JB4 is on now! and I have a set of spark plugs and I ordered coils to get that done with so I can really have some fun!
