TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > If you installed FF wires, click here
      06-18-2014, 10:27 PM   #1
Jsoboti
Jsoboti's Avatar
28
Drives: 2011 335i E92 M-Sport 6MT
Installed flex fuel wires today and immediately got the code 2C86, code is...
" Boost pressure sensor, plausibility: Pressure before throttle valve too low when engine not running "
"Charge Air Pressure in Comparison to Barometric Pressure Too Low"
Its pretty obvious that clipping the two green wires coming from the TMAP sensor messed something up, or possibly that the TMAP sensor itself is having some issues but ive been emailing with Terry for quite some time and after sending a multitude of photos and double and triple checking all connections, we both seemed to be stumped.
Anyone else experience this or something like it? or just have some knowledge/advice for me?
thanks
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
      06-19-2014, 08:15 AM   #2
JETmn
245
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
They work great for me. I didn't get any errors at all. It really sounds like you didn't get the 2 green wires coming from the MAP twisted back together properly or the plug on the MAP is having an issue. Make sure the wires are pushed in to the plug all the way.
      06-19-2014, 08:25 AM   #3
mashimarho
BimmerPost Supporting Vendor
mashimarho's Avatar
2111
Drives: E92 M3 & F80 M3 & G82 M4
Hmmm ^ +1
Mashimarho.com /// Instagram /// Facebook /// Youtube /// sales@mashimarho.com /// (425) 582-7939
      06-19-2014, 09:49 AM   #4
1cleann55
44
Drives: 2011 335i
I didnt twist the green wires together fully and that caused some errors probably the wires arent twisted on properly on your end
      06-19-2014, 12:59 PM   #5
weehe126
1161
Drives: 2017 340i
Do you have the stock charge pipe? Have you checked to see if you have any leaks? Are you sure you plugged all the sensors into the right spots?
      06-19-2014, 03:02 PM   #6
Jsoboti
Jsoboti's Avatar
28
Yeah checked the charge pipe, took the JB4 off and everything is running fine. Sending the JB4 back into BMS for a check from them
      08-11-2014, 02:01 PM   #7
mustangivore
33
Drives: 2011 335i E90
Dumb question but are the green wires coming from the TMAP sensor part of the JB4 or the car?
MHD Stage 2+ FBO
      08-11-2014, 02:16 PM   #8
Jsoboti
Jsoboti's Avatar
28
TMAP on the JB4 harness
      08-11-2014, 02:48 PM   #9
mustangivore
33
Thanks for the quick reply! Directions indicate those wires are to be capped with wire nut. So they are no longer needed and can be removed completely instead of just capped and left in the car?
Any general advice for future users of FF wires with E85? If you wanted, could you use just 93 pump gas with the FF wires without issue, and switch back and forth with E85 mixed with 93 pump? If desired, can the TMAP wires on the JB4 harness be reconnected if the FF wires are ever removed?
Thanks and sorry for the dumb questions.
MHD Stage 2+ FBO
      08-11-2014, 04:33 PM   #10
Jsoboti
Jsoboti's Avatar
28
1. I suppose you could remove the wires, but thats a lot of work and somewhat risky IMHO
2. You can switch back to straight pump gas if desired, just make sure the either "reset" map 5 by selecting another map and then going right back to 5 so it can create new valued and adapt for the current octane and ethanol content. When you do put E85 in the tank, after a few miles you can go ahead and do some hard pulls in map 5 to let it adapt. Any time you change the fuel with regards to E85 its a good idea to go ahead and do this.
3. I assume the wires can be reconnected as long as you know what to connect to what. should be fine
