05-11-2013, 10:18 AM | #89 |
19
Rep 338
Drives: VW TDi & BMW M3
Just placed my order for the EU switch from ECS, just because I'm OCD like that
2013 E92 M3 | Le Mans Blue | 6 Speed Manual | Competition Pack | Premium Pack | Cold Weather Pack |
05-11-2013, 11:21 PM | #90 |
Air Traffic Controller
Rep 26
Drives: 2012 E92 M3
Well done! I almost bought the switch, but it's way more rewarding to have it "hidden."
I released BOTH the top and bottom buttons and the "force headlights on" when the switch is on "Auto" works like a charm - let's call it a "twofer"!
Last edited by pilotchip; 05-13-2013 at 12:30 AM.. Reason: Headlights confirmed working! |
06-29-2013, 02:17 PM | #91 |
225
Rep 599
Super easy. Hardest part was prying the clips on the black button back to release the button... If you have them, good plastic tire irons work in place of a trim pulling tool. Worked awesome...
08-06-2013, 09:27 PM | #92 |
19
Rep 338
just installed my euro switch, thanks for the write up
08-27-2013, 08:41 PM | #94 |
218
Rep 882
Drives: 2013 ///M3 E92 DCT ZCP
Excellent post. Done in 15 min. Thank you. This will help in Florida given the sudden blinding pouring occasional rain. Thanks buddy.
08-28-2013, 02:02 AM | #95 |
80
Rep 945
Just did this tonight. Both buttons. Since I have an '08, I had to perform the Lego mod. However, in my case, it was the dowel rod and Duplo mod
This creation, combined with one or two felt pads was sufficient to bridge the gap between the buttons at front and the circuit board at the back. Thanks, OP, and all who contributed to the thread! Updates: Rear fogs work just fine. However, I'm getting no dash lights indicating such on my very early-model 2008 launch E90. Also, unless I gummed up the top, instant-on headlight button (certainly a possibility), I'm not getting this functionality--lights on auto, press button: nothin'. I'll update later if things change and I'm able to get this button to work as intended. OK, so maybe I was smoking something the other night. Turns out, the rear fog dash light is working for me. I think I may have not seen it the previous night. Then, when I was checking it during the next day, the headlights weren't on. Therefore, it makes sense that the rear fogs wouldn't come on then Last edited by gimmethemuumuu; 08-29-2013 at 04:08 PM.. |
09-17-2013, 02:38 PM | #98 |
80
Rep 945
Awesome!
Anyone with a 2008 unable to to get the top button working to instantly turn on the headlights when in (A)uto mode? I'm wondering if I didn't get things put together right there or whether it's possible with an '08? |
12-22-2013, 04:31 PM | #99 | |
164
Rep 658
My 09 E90 didn't have the extension either and I couldn't find a good spacer but the bic pen cap was the perfect solution - perfect fit in the button, easy to cut down to size (I cut it a few mm past where the end of the clip is molded into the cap), and rigid. I wrapped the cap in 2 layers of electrical tape so there was a snug fit into the button and so there wasn't plastic on plastic rattling. I hot glued the bic cap to a rigid plastic sheet cut down to make a "T" to hit both buttons and test fitted it so the detent of the rubber buttons on the circuit board was tight against the button (so the button does not sag). Done in less than 15 minutes and works perfectly. Why don't we get these functions in the states? |
12-29-2013, 05:57 PM | #101 |
2008 e92 M3 MT
Rep 5
OK I finally found the time to retrace my steps and the clue is that both contacts need to be pressed simultaneously. Since I had to do a makeshift "lego mod" (mine is an '08)
it was tilted slightly when depressing the switch. Mod now works ! awesome. |
03-14-2014, 09:34 AM | #104 |
689
Rep 1,530
Drives: '11 BMW M3
Do you have to purchase the whole ECS Euro Headlight Switch assembly just to get the rear fogs button? I assume even if you can find the individual button, it will not light up without the true Euro Headlight Switch. If you do, can you swap back in a blank from the stock assembly instead of the front fog button to accurately reflect the M3 lighting configurations after performing this mod (since we don't have front fogs)? Thanks in advance.
New: '11.5 e90 M3 | DCT | Space Gray/Novillo | ZCV | ZCW | ZP2 | ESS 625 | BPM | M Performance | iPE | BC Racing | BPM | iND | LUX | Volk | Coby | Recaro
Sold: '11.5 e92 M3 | DCT | Mineral White/Novillo | ZCP | ZCV | ZCW | ZP2 | M Performance | ACM | BPM | iND | Thule | LUX | Macht Schnell | Broadway Static | Rogue Engineering | BBS | Challenge | Metak |
03-14-2014, 09:40 AM | #105 |
8930
Rep 4,107
I bought the Euro switch from ECS, it does not have the front fog switch. I have included a link to the proper switch with chrome trim, for cars with rain sensor but no front fogs.. It is an easy swap, took 5 minutes. Just be careful popping off the dash trim pieces so you don't scratch them... More expensive route than the DIY but I like the properly labeled button on the Euro switch.
http://www.ecstuning.com/BMW-E90-M3-...hes/ES2500537/
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
03-14-2014, 09:48 AM | #106 | |
689
Rep 1,530
Drives: '11 BMW M3
Then I saw they offered it as you described which satisfies my OCD, ha.
05-19-2014, 11:21 PM | #107 |
IG: @dj_dub
1806
Rep 1,452
Drives: 2010 BMW E90 M3 - SG/FR 6MT
Thanks to this DIY, I finally did this mod…but opted to purchase the OEM Euro Headlight Switch instead. Very happy with the outcome! Thanks OP for creating this thread!
IMG_4780a by dj_dub, on Flickr IMG_4809a by dj_dub, on Flickr IMG_4821a by dj_dub, on Flickr IMG_4820a by dj_dub, on Flickr
CarboProject CF Plenum | Dinan CF Intake | ESS Tune | RKP X-Pipe | Akra w/CF Tips | MFactory CF DS | CSF Cooling | AST 5200 | Hotchkis F/R Sways | SPL/Ground Control/Fall-Line Arms | DEFIV Diff Brace | StudioRSR Rollcage | 3-piece BBS RT88 | Michelin PS4S | Brembos F/R | Recaro Profi SPG XL | CAE Ultra Shifter | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF SS | Varis CF Lower Tray | Turner Skidplate | BayOptiks Headlights
05-20-2014, 08:51 PM | #108 |
112
Rep 1,260
Does anyone know if we have the wiring for the front fog like the non-M e90's and 92's???
Just wondering if i can use the top switch if it's already wired. Thanks,
05-20-2014, 09:42 PM | #109 |
2760
Rep 6,761
There are no front fog lights on the M3, so no there is no wiring.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
