02-29-2024, 12:22 PM | #1 |
Rep 26
B47 noise/vibrations at the last second of shut down
Hello,
My B47 suddenly makes strange noises just before it comes to a standstill. I recorded this once and can't identify the source, maybe someone already had it. It can be heard in the last seconds 7-8, a knocking shaking noise. They only does that when the engine is warm. It doesn't do this when it's cold. He always used to go out with a gentle Frrrrr recording New Intake manifold original BMW February 15, 2024 New engine mounts original BMW 12.2023 No vaults present in IST*
3ér GT F34 (190PS), Motor: B47, Automatik, Bj. 07/2015, km: 207.000
03-06-2024, 10:59 AM | #2 |
Rep 26
I have replaced all Seals in the Air System and the result was the same.
But i have find out that the nois comes only in Position " P " , if i shout down in " D " or " R ", the engine stoped perfect. Is there a problem in the 8HP gear box?
03-06-2024, 02:45 PM | #5 |
290
Rep 482
fliyer
Hey, not much help, but I came across this thread seems to be talking about the same issue that you are describing: https://www.bimmerforums.co.uk/threa...utdown.590108/
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
03-06-2024, 03:22 PM | #6 |
8280
Rep 16,145
FWIW I never put my car in park before shutting the engine off, I always leave it in gear and let the car put itself in park when I turn the engine off. The car doesn't mind it a bit.
03-07-2024, 07:57 AM | #7 | |
Rep 26
Yes i know, but there was no result till yet
03-07-2024, 11:34 AM | #8 |
Rep 26
So, I just had the car on stage and it was always turned on and off, the gearbox swings back and forth quite a bit when turning it off/on. The noise comes from the very back, near the hardy disc flange. There is no oil leak there either.
I'll change the transmission mount tomorrow and see if that helps. Visually they don't look defective, but that doesn't mean anything.
03-08-2024, 11:30 PM | #9 |
Rep 26
It's unbelievable what I've just discovered. The wrong transmission mounts are installed in the vehicle.
In my pictures you can see that the 6875904 are installed, these are actually for a petrol engine and are much softer than those for the diesel. The correct number would be 6796617, this was never changed by BMW. I think in the past the bearings were replaced and incorrect ones were installed. These move a whopping 8mm more under max. load. Both are visually the same, but have a different rubber mixture. Well, I'm excited about the change. Here again is my storage of what I need: I had to delete the link again, the page then goes to Leebmann's unfiltered page with all the locations there are. But all the BMW dealers in North Rhine-Westphalia I called always said "not available at the moment" until the end of March. Great, I would have liked to pick up the stock from my dealer for €24. So now Leebmann has to wait. Here is proof again that it is wrong that 6875904 was NEVER installed in the F34. I left the engines hidden in the picture, but believe me, there are no diesel engines.
03-13-2024, 11:07 AM | #10 |
Rep 26
the parts are OK , i have take a look onto the drawing, 4 part numbers are printed in the rubber.
today i have change the mounts but nothing has change
03-21-2024, 10:38 PM | #11 |
Rep 26
I have called ZF and they think, that the parking brake hase some issues.
Next week i will visit ZF in Dortmund Germany
