      06-03-2022, 11:29 AM   #23
cukeuk
cukeuk's Avatar
142
Drives: Series 2 GC M235i xDrive
OK thanks, mine's still not done this, keeping my fingers crossed. However did yours make this noise when the brakes were either hot or cold or it was just random and not temperature related?
Cheers...
      06-03-2022, 01:36 PM   #24
LuCanBimmer
Drives: M235i GC
Cheers...
It's after a long drive, so it would be temperature related. So a swap in the brake rotors, sounds plausible.
      06-03-2022, 06:38 PM   #25
SimonCW
SimonCW's Avatar
46
Drives: F44 M235i XDrive Gran Coupe
Cheers...
Definitely not temperature related. It didn't do it all the time, just on odd occasion. My BMW dealership already had a bulletin about this problem so when I took it in they knew straight away and told me the rear brakes need replacing.
BMW M235i Gran Coupe Storm Bay Black Dakota Leather M235i Plus 19"552M Double-spoke Alloy Wheels Technology pack Comfort pack 2 Panoramic Sunroof Driving Assistant Pack
CoopJet3917.00
      06-04-2022, 12:21 PM   #26
Bimmerworld76
10
Drives: M5
Originally Posted by haze 11 View Post
i have a 2021 m235i gc UK spec and recently after a bit of a drive somewhere if i then reverse into say my drive way or a parking space there will be like a mooing noise and vibration from the front brakes, now i had booked the car into the local bmw dealer to check this over and they came back with the conclusion nothing was wrong as they couldnt identify the noise whilst it was with them as the noise wouldnt appear, any way long story short there was something to do with an engine mount need replacing so they did that and i had the car back yesterday and i had just been out in the car to get some lunch and what happens when i reversed the noise appears. someone please help me understand why this is happening.
I have awful whine from the car, not identified where it's coming from only when reversing. It is always when reversing at slow speed but it seems to do it sometimes without the brakes applied.
I also have the M235i gc and it pretty much done it since new but getting worse.
      06-05-2022, 06:35 AM   #27
cukeuk
cukeuk's Avatar
142
Thanks for the information Simon..
      06-06-2022, 03:32 PM   #28
MugatuJag
17
Drives: 2022 BMW 228I XDrive GC
Hey I have a 228 I 2022 X Dr. and my car has been doing that since I got it at 5400 miles, not temperature related, every time in the morning but also throughout the day, did the dealer replace the rear brakes for free, and do you have the TSB by chance? Thank you
      06-06-2022, 06:05 PM   #29
SimonCW
SimonCW's Avatar
46
Dealership replaced it for free under BMW warranty in UK.
      06-06-2022, 08:53 PM   #30
MugatuJag
17
That’s cool, I did not buy the brakes package for my car because I have a 30k mile lease and they may not even need pads or rotors, but if so I can change them for cheap. So did the dealer confirm they were able to re-create the noise, or did you send clips of it happening? I just want to be prepared, thanks
      06-09-2022, 04:56 PM   #31
MugatuJag
17
Do you have the work order by chance for the brake issue? My car is going into the body shop after a minor accident and I’m gonna have them look at that. I have to remember to revert all my coding back to stock, put my stock intake back in, and plug back in the actuator valve on the exhaust lol
      06-15-2022, 07:42 PM   #32
Mishta.Silva
20
Drives: BMW M235i Gran Coupe
My dealership just called. They were able to hear it, but have said that it's a "normal characteristic" of the car … between the clicking noise the car makes on hard acceleration and now this… this M235 seems to have a lot of unappealing "characteristics".
CoopJet3917.00
      06-28-2022, 05:51 AM   #33
Allen Aquino
Allen Aquino's Avatar
269
Drives: BMWM8 Gran Coupe
Have had an similar experience way back
Mosset0.00
      11-29-2023, 04:49 PM   #34
RyeOMye
Drives: 2021 228i
My 2021 228i does this as well, but I am pretty sure it is a resonance issue coming from the underbody paneling as a result of braking in reverse. I am specifically looking at the panel just behind the rear axle line that is supported by lightweight metal framing, and thus more susceptible to resonance. Just assumptions at this point, but I plan to install some sound dampening material on the topside of those panels to see if that helps. This is why the sound tends to linger moments after you stop braking and why it can temporarily go away when you have your brakes serviced. IMO, it's a design flaw. I will keep you posted as to the results of the dampening experiment.
      11-30-2023, 12:42 PM   #35
Shra1ZN
Shra1ZN's Avatar
South Africa
Drives: F44 M235i
2022 F44 M235i  [10.00]
I also have the same issue when reversing with full swing to the left. There is also a grinding noise on the brakes after cold start. I notified the dealer they checked the brakes and found the rear brakes down to 4mm in under 16000km/10000mi. Brakes were changed under warranty and they have not told me what the issue is.
I am awaiting a courtesy car from them to check the brakes and also a rattle in the roof.
Other than these 2 issues, I am truly enjoying this car, it is so much fun to drive.
      01-25-2024, 06:49 PM   #36
mblaucoupe135
287
Drives: 2022 M240i
Any update on this issue? My wife's car made this noise really bad during the recent cold snap recently so then I was thinking it might be temperature related. Also a few months ago I switched the pads to an aftermarket one and still get the mooing noise periodically.
      01-28-2024, 08:07 AM   #37
Shra1ZN
Shra1ZN's Avatar
South Africa
Drives: F44 M235i
Still waiting for a courtesy car from dealership.
      02-14-2024, 06:06 PM   #38
egorix
Drives: BMW M235 (F44)
Exactly the same happening on my car when going in reverse on a specific low speed. And the sound progressed to happen when moving forward after rear pads replacement. However it went away after around 1.5k km. When going in reverse - still happening. I guess this is not fixable thing. Or it doesn't need fixing.
      02-25-2024, 12:52 AM   #39
Shra1ZN
Shra1ZN's Avatar
South Africa
Drives: F44 M235i
Finally got my car in.
They haven't told me what the problem is however they mentioned that they did a "2 Stage Compound" on the brakes, whatever that means.
Happy to say, the mooing went away.
However one week later the brakes are now squeeling like an old jalopy.
Can't win!!
      03-20-2024, 07:24 AM   #40
Nikysan
Drives: BMW M235i F44
I got this going in reverse a few times. Its a mystery across all forums!
      03-24-2024, 02:16 AM   #41
SnapperRoxGC
SnapperRoxGC's Avatar
23
Drives: 2020 M235i GC
Eh, they are performance brakes. Any performance brakes when they are cold at low speed are going to sound questionable, ask anyone who owns a car with carbon ceramics. It's a minor 4 second long annoyance when I'm backing into my garage, and that's the extent of it for me.
Shra1ZN12.00
      04-02-2024, 09:26 AM   #42
nmx77
Drives: E46
Hi,
I’ve just come across this thread as I’ve now had this noise for a year. The car is E46 and a 52 plate. No issues until front near side caliper and both front discs and pads changed last April. The noise is driving me mad. It started when reversing with the steering wheel turning ie to reverse park but then also will make the noise if the car is in 1st but rolls back, for example while at traffic lights. The noise stops when the brake is applied. The garage were convinced it was a steering issue - new full system and noise is still there. It only happens when car is warm and definitely a resonance rather than a grinding. It also seems to sound as though it’s at the front rather than the rear. If anyone does find the cause of the problem I would be eternally grateful, it’s driving me to distraction
