04-08-2019, 12:22 PM | #155 | |
260
Rep 714
I want to get one of the spare tires for the x5 though, as I don't plan on ever running runflats. On long trips when towing I just throw a winter wheel on the trailer with all the drift spares. |
9vapors653.50 |
04-08-2019, 01:11 PM | #156 | |
30
Rep 60
Left side requires a lot less trim removal. You will need to move the coolant reservoir a bit to gain access to the front nut. Just remember to torque the through bolts with load on the suspension. I did this with the wheel off and lifted each corner with a floor jack. The genuine set is a fixed/non adjustable at .5 negative and about $300ea. I ordered mine off ebay with these part #s 3160500033HD 3160500034HD
/// 07 3.0
04-08-2019, 01:22 PM | #157 |
The Doctor
14
Rep 170
Installed side decals, took about half an hour
2007 335i: Evolve tune, AR Catless DP, VK FMIC, Vorsteiner lip, VRS CSI bootlid, Lux V3, RD strut bar, P3 Boost guage, PSW, BMW Performance Power Kit, Injen intake - TOTALLED by son
2013 X5M: VRS lip, Velos Tune, Catless DP, Dome hood, electric trailer hitch, performance alcantera SW. |
04-08-2019, 03:27 PM | #158 |
211
Rep 433
washed and cleaned the interior yesterday
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread https://www.xbimmers.com/forums/show....php?t=1529213 |
Nyc Dito112.50 |
04-08-2019, 08:05 PM | #159 |
2038
Rep 3,044
Drives: 2022 BMW X5
04-10-2019, 08:32 AM | #160 |
47
Rep 138
Added Lux LED angel eyes and some oil saver for my minor oil leak. Dealer says it's the oil pan gasket, but Indy says it's not bad and he wouldn't mess with it yet. Hoping the oil saver helps restore the gasket.
2012 X5M /// Velos Stage 2 /// xHP Stage 3 TCU tune /// Sprint Booster
2013 X3 35i M-Sport |
9vapors653.50 |
04-12-2019, 10:26 PM | #161 |
Rep 62
Worked on my wife's 2013 35d. Front and rear brake pads and sensors today as well as flushing the fluid. Lots of rust so they took me a lot longer than I anticipated. I sprayed the bleeder valves with wd40 at the beginning of the job and they broke loose without too much trouble. Wasn't sure what the caliper bolts were so I took this pic. (7mm internal hex)
9vapors653.50 |
04-13-2019, 10:32 PM | #163 |
75
Rep 212
Drives: 2008 e90 335i, 2012 X5 M spor
washed and added slotted and drilled rotors.
04-13-2019, 10:58 PM | #164 |
654
Rep 1,252
04-15-2019, 04:22 PM | #167 |
112
Rep 357
Drives: E70 X5M
Also, what width are those rear wheels? Are you running a square setup with the 22" wheels? Looks like the rear are same as the front...
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
04-15-2019, 10:44 PM | #169 |
1398
Rep 762
Drives: 2019 BMW X6M
Changed out the center rear DIFF oil, going to do the L & R next. The front DIFF looks like it's going to be a PITA.
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
04-16-2019, 01:16 PM | #170 |
260
Rep 714
Well this weekend I towed my drift car to it's first event. The 35d handled it like a dream!
Except yesterday, on my way to work, I got a wild vibration, and droning noise, that tells me I pushed one of the rear wheel bearings past it's limits. More than 217k miles on those bearings, it's about time they went! I've actually had a decent highway vibration from the rear since I bought it, but never figured out what it was. Now that it matches up with the drone/ grind, I realize it was likely the bearing starting to go for the last 10+k miles. I'm hoping it's nice and smooth after it's fixed tomorrow! |
04-16-2019, 05:21 PM | #171 |
83
Rep 254
I used the middle terminal of the positive block on the battery for the positive lead, and used a common ground at the base of whatever module is to the right of the battery. It showed minimal resistance and great ground attributes and good bolt width for just the 4 AMP push that I have going into the hatch.
I went with this tender: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 AND I added this extension cable for the run between the battery and the tender. I want to put as much distance between them as possible and this works well: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
04-16-2019, 06:49 PM | #173 |
112
Rep 357
Drives: E70 X5M
Damn looks great man. That's not a small addition - really want to pick one up one day. Pissed they didn't throw them on the X5M from factory.
9vapors653.50 |
04-16-2019, 06:59 PM | #174 | |
654
Rep 1,252
They've come way down in price, just $1299 from ECS... |
04-16-2019, 07:19 PM | #175 | ||
112
Rep 357
Drives: E70 X5M
What parts is your shop waiting on to finish everything up?
04-16-2019, 08:19 PM | #176 |
654
Rep 1,252
Right, but you don't need them to do it and can do it after the fact if you're on a budget.
Waiting on the under hood insulation, even though I told them several times, they didn't order it. Some clips for the insulation. Also had them install my piano black interior! |
